Results 1 to 4 of 4
    Sep 04 2010
    West Coast
    Red face Quick Questions on VMR 19" fitment on S4
    Hi,
    I just got my brand new S4 last week. I am wondering which offset fits the B8 S4 better? I am stock with stock height and not planning to lower it.
    Should I get 19x8.5 +38 or 19x8.5 +45?
    What is the recommended tire size? Should I get 255/35/19 or 245/40/19. The 245 has a $40 difference each.
    Finally, is there a TMPS on the 2011 S4? Because if there is one, I would have to unmount my OEM wheels and swap the TMPS onto my VMR. If there isn't any I can just purchase the wheels with tires mounted.
    Thanks in advance.
    Mar 26 2010
    US
    I put on the VMR 708 wheels, but they are 18" diameter, by 8.5" wide rims and ET=38mm. VMR said the ET=45mm might not clear the suspension on these wheels. I am using stock size tires 245/40R18.
    The offset depends on wheels width and tire size. One can use spacers if the wheels rub the suspension.
    There are no TMPS, it is calculated from the ABS sensors and wheel rotation speed.
    I guess the stock 19" tires are 255/35ZR19 (26.1" diameter, 10.3" section width), but the 245/40/19 (25.7" diameter, 9.8" section width) would provide more clearance.
    The guys at VMR may be able to provide guidance on the offset.
    Check with LOU on this;
    http://www.audizine.com/forum/member.php/47271-L0U
    2019 RS5 Sportback
    Sep 30 2009
    b
    18x8.5 et 38 would be nice on a 255 or 245, you can run either without much problem. I would run some spacers in the rear atleast. You could even run 5mm front and 10mm rear.
    Senior Member Three Rings sworksone's Avatar
    Oct 11 2009
    You should run the 19X8.5 et38. I run 19" VMR V718's in 8.5 width in et35 (stick 3mm further out) without any issues. The tire size is 255/35/19 and as mentioned, B8 S4 wheels do not have TMPS sensors (it's indirect from the ABS system).
    2005 TT S-line, Papaya, 3.2, DSG
    Retired 2014 S4 Technik, Glacier, Black Optics, Black/Magma, Sport Diff, DSG
    Retired 2010 S4 Premium, Ibis, Black/Magma, ADS, 6MT
    Retired 2006 A4 S-line, Quartz Grey, 2.0T, 6MT
    Retired 2002 A4 S-line, Brilliant Black, 1.8T, 5MT
