Results 1 to 39 of 39
    Dec 27 2008
    B8 S4*07 Z4 M Coupe*2009 BMW X5 3.5D
    Northern NJ
    APR Chip Question
    I know these are probably stupid questions but it always makes me feel better if i just ask. I just got my chipped ECu sent back to me from APR today but i am not at home to install it untill tomorrow so while i sit here thinking about how bad i want to drive the car i figured i would ask some last min questions.
    How do i activate the prgram once its installed? Do i have to do anything or is everything automatic? Can and how do i deavtivate? If i bring the car to the dealer is there anything special i should do?
    I had my ECU prgramed for the 93 octane if for some reason i use a different grade beside 93 what will happen? I dont plan on doing this but i just would like to know just in case??
    I appreciate the help in advanced!
    Apr 29 2010
    victoria bc
    as its the only program it should be plug and play. with the octane it will just retard timing so it shouldn't be an issue....you will be down on power but it wont break anything
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by kailuaboy View Post
    Exactly, just pop it all back in and start your engine!
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Dec 27 2008
    Northern NJ
    Awesome! I kind of figured this but just wanted to get everyones feedback to make sure!
    Registered Member Two Rings
    Dec 23 2008
    Opelika, AL
    If you purchased the 93 octane file, you need to run 93 octane. PERIOD. With lower octane fuel it is absolutely possible to harm your engine despite the protection strategies in place. If 93 is not available where you live we'd be happy to reflash you with the 91 program.
    Registered User Four Rings primetime's Avatar
    Mar 05 2010
    4 four ring cars and 1 P-car...
    Quote Originally Posted by Joel@APR View Post
    Joel, Hey man.. just getting started with vagcom.... Do you know how to convert G436 value of 1878 to psi... Am I pulling the right value to measure boost? Car made 434.17 tq at 6614 rpm.... Very impressive....
    Sep 29 2009
    Glad you got VCDS working for logging! Is it possible that 1878 is 1.878 bar?
    ** edit, not bar, that would mean multipliying by 14.xxxx and would mean over 27 PSI, so def not bars.
    Established Member Two Rings romanvn106's Avatar
    Dec 17 2009
    gs350
    brooklyn ny
    also when is the new program going to come out ? beacuse i would not be able to bring it in for service
    Sep 29 2009
    Quote Originally Posted by romanvn106 View Post
    If you mean the ability to swap between programs and return it to stock, the last I heard they were shooting for before Xmas.
    Mar 26 2010
    US
    1,878 hectopascal = 27.24 pound/square inch
    27.24 absolute psi -14.7 ambient psi = 12.54 psi boost
    http://www.onlineconversion.com/pressure.htm
    2019 RS5 Sportback
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by primetime View Post
    1871 mbar - 1000 mbar (estimated) = 871 mbar.
    871 mbar * .0145 = 12.632787 psi
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Mar 05 2010
    Thanks guys! Forgot about having to subtract out 1 bar for ambient air.... I was coming up with over 25 and new it wasn't correct....
    Veteran Member Three Rings rktskicar's Avatar
    Dec 12 2009
    Quote Originally Posted by Arin@APR View Post
    2nd.
    Bruce
    Bruce
    "I think the car is too damn quiet and smooth. It doesn't seem like you're hauling ass until you look down at the speedometer."
    Stock ECU, Sprint Blue 6MT 010 B8 S4, Premium +, B&O, sport diff, black Nappa, BBS CH, 255/40/18 Bridgestone RE960 AS
    Milltek resonated cat-back & DPs
    01.5 6MT ASP Stage 3 B5 S4 (4/01 to 9/09)
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    On a related note: 93 is available where I live, but I recently took my car to Canada, where the best I could find was 91. If I occasionally travel to places that have no 93, what are my options?
    Dec 23 2008
    Opelika, AL
    If you have access to Vag-Com, you can log the amount of timing retard on each cylinder while using the 91 octane to determine if it's safe. If not, you can drive conservatively while the 91 is in your tank until it is all out. However, timing is advanced at every rpm and at all loads with 93 vs 91 so this is still not ideal. It would be unwise of me to tell you it'll be okay in all circumstances but if you have to get 91 you should at least get a quality brand.
    If you're ever forced to start using 91 often then I would send your ECU back to us for a reflash. There's only a 9hp difference between the two files and if you have access to 93 you'll actually gain some of that horsepower back.
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Quote Originally Posted by ibiski View Post
    Keep couple cans of 93 in the trunk ;)
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    This might sound dumb but how many points can an octane booster help?
    Dec 12 2009
    The long term solution is obvious for APR. Have EMCS with both 91 and 93 programs. EMCS should be available in Dec. for this car.
    Bruce
    Aug 31 2010
    New York City
    how was the stony meet?
    Dec 17 2009
    gs350
    brooklyn ny
    it was fun i got ripped by a b5 s4 with 600 hp. on the good side i took a rs4 by about a car and a half
    Apr 29 2010
    victoria bc
    good to know about the octane. thank you. thank god i have 94 up in the great white north
    Feb 11 2010
    Around here (Seattle) all I seem to recall seeing is 92 octane. Or am I just remembering it wrong? Is there a setting for that with the APR chip, or do you have to choose between 91 and 93?
    Sep 29 2009
    Quote Originally Posted by uberartist View Post
    No, you are right only 92, you can safely use the 93 here, as all ours has 10% ethanol which combats knock.
    Established Member Two Rings WhssssS401's Avatar
    Oct 17 2010
    1990 300zx NA
    Sioux Falls, SD
    Since we are talking about apr chips, I have a 01 S4 that is now upgraded to a stage 2+ and now wondering what the adv. is to upgrading to stage 2 apr ecu. Also can they eliminate the rear o2 sensor cel code since I am soon putting test pipes on. Just a few questions I had.
    2001 Audi S4 Stage 2+
    APR Tuned Chip | Draintake Intake | 710n's | RS4 Clutch |
    ECS Light Flywheel | Piggie/Test Down Pipes |
    3" MagnaFlow Custom Exhaust | 18" HR8-MS Hartmann Wheels |
    225/40ZR/18 Continental Ext. | Vogtland GT2 coils | RS4 Bumper |
    Erik N.
    Oct 17 2010
    1990 300zx NA
    Sioux Falls, SD
    forgot to mention I have a stage 1 apr chip already installed just looking to upgrade
    Erik N.
    Sep 29 2009
    Quote Originally Posted by WhssssS401 View Post
    Are you asking about the stage 2 in general or specific to your or the B8 platform? If you want to know the advantages on your platform, the APR site should compare what the differences are. For ours, it will entail adding a pulley to increase supercharger RPM, and a tune to the chip to take full advantage of these characteristics and changes.
    Oct 17 2010
    1990 300zx NA
    Sioux Falls, SD
    no I know what stage 2 is in general but i'm more asking what the difference is between the apr stage 1 ecu and the stage 2 ecu upgrade, just asked since this was about apr but I can always just call them too
    Erik N.
    Aug 23 2008
    Auburn, AL
    There is only 1 ECU upgrade right now. Stage 1.
    Oct 17 2010
    1990 300zx NA
    Sioux Falls, SD
    ohh ok so now I am confused lol cause on the website there is 3 drop down menus for stage 1, stage 2 and stage 3 ecu upgrade for the B5 S4 2.7T ecu , Telling you the requirements/recommended hardware for each stage upgrade. So... Whats the difference??
    Erik N.
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    The confusion lies in talking about a B5 and b8 in the same thread. As of right now only stage 1 can be bought for the b8 when it comes to a software tune.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Sep 29 2009
    So, you are in the B8 specific forum first off. We welcome new people, but won't have a lot to contribute to what mods and such there are for your platform as much as you would in your home (B5 S4) forum.
    In looking at the APR site, it looks like this is how it goes:
    Stage 1 - ECU tune, no hardware required but Recommended: APR R1 Diverter Valves, APR Bi-Pipes, APR Catback Exhaust, APR Intercoolers
    Stage 2 - ECU tune (free if you have stage 1 already) and required hardware: APR Downpipe Recommended: APR R1 Diverter Valves, APR Bi-Pipes, APR Catback Exhaust, APR Intercoolers
    Stage 3 - ECU tune (free and included with required hardware) and required: APR Stage III Turbo Kit and APR Full Exhaust Recommended: APR R1 Diverter Valves, APR Bi-Pipes and APR Intercoolers
    Oct 17 2010
    1990 300zx NA
    Sioux Falls, SD
    haha Sorry My bad I thought I seen B5 now it makes scene why there was confusion lol. I'm just going to contact apr just easier anyway. Thanks for the clarification and sorry to confuse you guys
    Erik N.
    Aug 09 2010
    Singapore
    Quote Originally Posted by NWS4Guy View Post
    wonder when APR's gonna give us their intercooler / downpipe for the B8 S4 kekekee that would be nice :)
    Jan 15 2010
    North
    Question for APR. I have access to Shell premium which is 91 octane but has zero ethanol. I also have access to Sunoco 94 octane but it contains ethanol, upto to 10 or 15%, forget which one. Which is better? I keeping hearing that ethanol is not good and is just used as an octane booster whereas no ethanol 91 could be better. What is right?
    Senior Member Three Rings MANNYS4's Avatar
    Nov 16 2009
    dallas
    Dumb question here but when you Reflash your ECU example 93 oct , can you still use fuel with additives like Shell or Chevron?
    2010 S4 Phantom Black /APR ECU 93 OCT / KW V2 / Black Optic Grill / Miltek Exhuast NON RES QUAD TIPS/Forgestar F14
    Apr 21 2010
    Florida
    Quote Originally Posted by compguy View Post
    All else equal, ethanol-free gasoline is the best and will give you the most energy per combustion event (otherwise known as torque). However, all else is NOT equal between those gasolines. The 94 starts out with a higher octane, which will allow more timing advance without detonation. This will combat some of the energy loss from having ethanol and likely can even make up for it completely, especially with a tune. 10% ethanol isn't terrible for your car, but given the choice with equal octanes I'd definitely go non-ethanol. Ethanol is naturally more resistant to premature detonation than Gasoline, but just because you see something labeled 93 with 10% ethanol doesn't mean it will be more knock resistant than standard 93, so don't count on that.
    Just to give you an idea of the effect of ethanol on engine efficiency, they just switched from their summer (read: ethanol) gas mix to their standard mix here and the difference is quite noticeable. I've seen ~2mpg through a tank and a quarter of the non-summer stuff with no change in driving style or type with the same grade fuel on my 08 Bullitt Mustang. Happens every year around this time, and mileage goes back down around April, and this is Florida so I'm still making use of my AC as much as usual.
    Feb 11 2010
    Looking at the most recent post by others, I'm confused about what to believe. Saying that 93 with ethanol isn't as good as pure 93, but that 92 plus ethanol works with the 93 APR tune confuses me. Can someone from APR give their opinion? For the whole area, it seems we are 92 with 10% ethanol--what program do you suggest, 91 or 93?
    Sep 03 2009
    I'd use the 91 flash for now, and then with the upgrade you'll have acess to 91,93,100
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Sep 29 2009
    straight 93 is much better (for power and economy) than 92 plus 10% ethanol, but ethanol helps prevent precombustion (knock) so 92 with 10% will allow more timing advance than straight 92 would, matching or surpasing what you can get out of 93 straight. The difference is that ethanol is an oxygenizer, and by burning it and releasing more O2, the ECU will cause more fuel to be delivered, because it sees more unburned O2 and thinks there is more to use and adds fuel to do so - not getting that the burning if the ethanol is what is causing it.
