Results 1 to 11 of 11
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    Rear Shock Mount - Should I be concerned?
    So I had my rear shock out last weekend to fix a cracked spring and found this. Thank you NYS DOT salt Nazi's.
    Structurally its solid but I was kind of surprised by the entire back plate disintegrating. Has anyone else seen this ?
    Oct 09 2008
    I am once again reminded as to why no one should every buy a used car from the North East.
    The Awesome™
    Veteran Member Three Rings T0mat3's Avatar
    Oct 05 2008
    Montreal, QC, Canada
    It has happened on both of my A4's, not a big concern.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Both of my rears are like that. I wasnt too concerned as its not really doing anything to help structure.
    Dec 19 2007
    Colonie NY
    Quote Originally Posted by JoshDub View Post
    Tell me about it...I feel bad everytime I drive in the winter
    Ok, at least I know mine isnt the only one like this.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    If you're worried about it then get a pair of rears from a junkyard.
    Jim
    I Do Werk.
    Aug 13 2008
    Indiana
    I don't see why the north east is the only place you think they rust? Mine was from Detroit and has 159,000 miles and doesn't look anything like that. Honestly these cars are one of the most rust resistant I have ever seen.
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    Wow I finally lucked out on something, I just replaced my non-oem oem-non sport suspension in the back. I put oem-sport in the back so I have a full sport suspension like it had originally from the factory, and mine did not look anything like that.
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
    Oct 05 2008
    Its not like it really matters, its facing the inside of the car lol.
    May 09 2009
    Syracuse, NY
    I have the same thing. I wouldn't worry about it.
    Veteran Member Three Rings BlkBullitt's Avatar
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    Both of mine are starting to rust... one has a hole in the rear section, but neither are as bad as the one pictured. It seems to be a fairly common issue. It's not a huge issue right now, but I'd plan on replacing them eventually if you plan on keeping the car for a long time (and I'd replace them asap if you see the sides start to get bad as I've seen a few posts by people who have had them fail where the shock mounts to them).
    If you have time before installing them you could do what I did to mine and apply a rust killing agent (Evaporust, etc) and then paint them with a rust resistant paint (POR-15, etc).
    2002 Audi S4 Brilliant Black Avant 6MT[/b]
    B5 A4 / S4 Headlight and HID Thread | B5 A4 / S4 Center Console Thread
