    Veteran Member Three Rings sxman69's Avatar
    Oct 04 2009
    08 CRF250R, BLKMRKT Mob, Giant Glory DH
    Auburn, CA
    Unidentified Clutch Pedal Activity [UCPA]
    The last few times I have driven my car, the clutch pedal has had about an inch of play in it. It seems like the clutch is not fully engaging, because shifts have been a little iffy lately, with some occasional rough feedback. Any ideas? master cylinder, clutch? I dont think the clutch is slipping really, but it does have 140,xxx miles on it
    -Sam
    New: 2009 Mazdaspeed 3 GT
    SOLD!!!! Staggared AMG Monoblock // Podi // Magnaflow // Forge // Kicker // Kenwood // JHM stud conversion // Tint //15mm H&R spacers // Hardwired Passport 8500 X50 // 034 Wiring Harness // Hawk HPS // 034 Blockoff Plate // MKIV Euro Switch
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    would you really be shocked if the clutch was bad at 140k? lol. there is always a tiny bit of play in mine but not an inch.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Mar 13 2010
    ontario, canada
    Most likely a leak in the master, line or slave. Any loss of fluid.
    Mar 13 2010
    ontario, canada
    Could try bleeding it also.
    Veteran Member Three Rings 1ScientisT's Avatar
    Sep 30 2009
    Cleveland, OH
    If you start getting more pedal play you may need a slave cylinder. When I had this problem on my old B4 I replaced the clutch master cylinder too.
