I've searched and couldn't find anything solid. I'm going to flush the system and was wondering if I needed any special tools? I was just going to flush it by bleeding all the fluid out with the pedal method. Is that sufficient enough?
05.5 B7 A4 longest running with no motor issues at 373whp
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
