Results 1 to 7 of 7
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    rev limit question
    hey so i searched this quite a bit on a few diff forums with no luck, why do the 6spd cars has a rev limit in neutral that spikes at 4 and then settles between 3600-3800 and if held for long enough will cut the motor even with your foot planted?
    TIA
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Veteran Member Three Rings vincent9993's Avatar
    Apr 02 2007
    Dune Buggy
    St-Leonard
    Launch Control?
    Nov 05 2006
    Fair Lawn
    thats what im hoping it is but know its not lol
    Jul 27 2010
    Singapore
    Quote Originally Posted by richib86 View Post
    TIA
    Protects the engine from damage.
    Feb 23 2010
    Burbank, CA
    Hold the esp button until esp and asr are switched off. Then you are free to rev with it in first gear and the clutch in!
    Veteran Member Three Rings Zed 2.0's Avatar
    Feb 12 2010
    San Diego
    Anybody know if there's a way to get around the rev limit in neutral with the S-Tronic? Trying to diagnose a whistle in my APR exhaust that only comes up over 4k rpm.
    Veteran Member Three Rings mdma2004's Avatar
    Aug 24 2008
    GCC
    You can use it as lauch control on the manuals, had fun spining all tires:)
