Results 1 to 17 of 17
    Senior Member Two Rings Rosinbag's Avatar
    Jan 27 2009
    TX
    Your RPMs at 80MPH? Am I imagining things?
    Howdy all - What are your RPMs at when cruising at 80MPH?
    I'm at about 2.5K right now. Does that sound right? Had an interesting situation last night - when WOT, turbo seemed to spool but failed to deliver that whump/burst of power (uh-oh, right?). I've haven't had the nerve to do it again, but I am noticing (I think?) my RPM's seem high at 70-80. Does 2.5K seem right for 80MPH? It seems to hold there when I let off the throttle, too. Am I imagining things? I have a chipped A4 2.0 QT tip. Thanks and peace.
    The Rosinbag
    '13 All Road P+
    Established Member Two Rings mikebo212's Avatar
    Sep 18 2010
    Burlington NJ
    That's pretty normal to be anywhere from 2.5-3.0k at 80mph, now for the failed turbo delivery I'm not sure but I don't think it's normal.
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    South Jersey
    i do around 2500 RPM @ 80 MPH with my b7
    The loaner A3 I have now does 3200 RPM @ 80 MPH. Interesting knowing it has the same engine.
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    Yeah, about 2500 RPM at 80 MPH in 6th gear is about right for me too.
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Jan 27 2009
    TX
    Thanks, Mike & GA. That is is weird, Shiro. Thanks, guys.
    The Rosinbag
    '13 All Road P+
    Mar 26 2007
    Colorado
    i drive in 5th gear on the highway so i can always be passing people and not downshifting...i think that puts me around 3100 RPMS
    CURRENT:
    2021 Atlas
    Veteran Member Four Rings crazytex21's Avatar
    Jan 31 2010
    Georgia
    Quote Originally Posted by vdubjetta02 View Post
    and quite a bit less MPGs, yeah?
    tex lee
    A lot of people think you want to race, when in reality, you just have to motor home because Chipotle.
    ~Shicky~
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    You can't pass people at 2500 rpm in 6th?
    Justin
    DTM S4 Sprint Blue
    Veteran Member Four Rings freaksavior's Avatar
    Jul 06 2010
    Houston
    Quote Originally Posted by Rosinbag View Post
    Are you implying you were driving and texting?
    Mine is about the same. 2500ish give or take
    Jul 26 2010
    Atlanta, GA
    Quote Originally Posted by elwigglero View Post
    Sure, but it takes a second or two to gather speed. I know what he's saying. If I'm in heavier traffic where I'll want to be able to bust a move quickly, I'll stay in 5th as well.
    Jan 27 2009
    TX
    [QUOTE=freaksavior;5787005]Are you implying you were driving and texting?]
    Yep, you got m.... adlkfjl.a..d, f...a...
    The Rosinbag
    '13 All Road P+
    Mar 26 2007
    Colorado
    well you could, but its quit a bit slower than 5th gear.... i drive aggressive to say the least
    CURRENT:
    2021 Atlas
    Mar 26 2007
    Colorado
    Quote Originally Posted by crazytex21 View Post
    actually no, a matter of 400 RPMS or so is not going to make or break or gas mileage. My k04 1.8t jetta only had a 5 speed and was around 3100 RPMS in 5th...i didnt have a choice and still got around 28 MPG on the highway
    CURRENT:
    2021 Atlas
    Veteran Member Four Rings italia8287's Avatar
    Jul 23 2008
    New York
    i think if im understanding it right, i had a similar problem and it was the intake motor flap that went bad. had it covered under warranty.
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    sounds normal.. my A4 did that, too.. and why don't you just rev match downshift to 3rd or 4th (depending on speed) when you need to pass quick?
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Jan 31 2010
    Georgia
    Quote Originally Posted by GA42.0T View Post
    what do you mean, takes a second to gather to speed? why does mine not do this... hahahahaha.
    tex lee
    ~Shicky~
    Veteran Member Four Rings ryanworth's Avatar
    Nov 16 2009
    Los Angeles, CA
    Yeah I can pass easily in 6th, way easier in 5th, and just take off in 4th. Not sure what the issue is here..
    Ford Focus - 2.0 Gray Four Banger Bad Ass Hatchback - Current
    B7 S4 - 6MT Dolphin Gray Avant - Old
    B7 A4 - 2.0T 6MT Quattro Brilliant Black Titanium S-Line - Old
    -Ryan
    F.T.W.L.T.B.D.W.I.C.T.W
