Results 1 to 7 of 7
    May 08 2009
    Easthampton, MA
    Hardware, where to find cheaper
    I'm wondering if anyone knows of a place, other than the dealer, where these bolts might be found.
    Bumper mounting bolts (the 2 long torx)
    Lock carrier mounting bolts, front (the 7 torx with wide heads)
    Lock carrier mounting bolts, sides (the 6 black smaller torx)
    Needs to be replaced from overuse... I find the dealer to pricy, about $50 for all screws... any ideas?
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    your local hardware store might carry them but also give www.ecstuning.com a try.
    May 16 2008
    South Texas
    Quote Originally Posted by Tomm View Post
    Those are all dealer items, you won't find those exact bolts in a hardware store.
    try Audis4less he can probably get you some good used bolts.
    ECS just resells dealer parts, so the dealer is likely the same cost.
    Dec 18 2005
    nevada
    Interesting, thanks for the info. but I was able to find a couple at NAPA.
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    I just bite the bullet and opt for dealer bolts, no hassle. I must have spent over 400 on bolts in the last two months. EVERY single bolt on my engine block has been replaced, I had no choice since my old bolts got stolen. There is nothing original on my block except the block itself, breather apadter and the pulleys. Even the dowel pins have been changed. Its a nightmare.
    MontrealAudiClub
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    go to a junkyard and pull what you need of a car, the junkyards i go to dont charge for bolts just because it would be more of a hassle for them to find a price for them
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    May 08 2009
    Easthampton, MA
    Anyone have the dimensions for those bolts?
    I figure i should give the hardwarestore a try...
