Results 1 to 16 of 16
    Established Member Two Rings doublebogey2's Avatar
    Jul 28 2010
    Pittsburgh PA
    Boosting problem and its not the TBB.. Any ideas?
    Been extremely busy with work and havent had time for my car. I didnt drive it actually took the bus. Anyways last night I got time i ordered a samco tbb and went to install it last night. Mine was perfectly fine. Really stumped. I have no idea where to look next. The car is definitely not boosting as much as it did say 3 weeks ago and it happened all of a sudden. It was boosting to 18-19 now its just reaching 15. I also noticed a new problem last night. For some reason in first gear its not registering any boost sometimes and other times it boosts to about 8. Anyone have any ideas. Could it possibly be a boost gague problem. Im thinking its not because it is still registering. Anyone with any ideas id love to hear them. Thx.
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    What year b5 do you have because you might have a flux capacitor problem.
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Have you done a boost leak test?
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Jul 28 2010
    Pittsburgh PA
    Yes. Nothing. Even tried using water with soap. No bubbles or anything. Any ideas?
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    Scan for codes, it could be EGT's
    My car is fast
    Active Member Two Rings noxplode's Avatar
    Sep 01 2010
    encinitas
    x2. if you have access to a smoke machine thats the most fool proof way as well.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    quould be uno malo turbo..
    RS6 hybrids and corn
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Sorry to dwell on the TBB, but did you check under the clamps for tears? Also, do you feel any stuttering or hear/feel misfires (ignoring what the boost gauge says for the moment on boost)? If you don't have a VAG, find someone to scan for you.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Jul 28 2010
    Pittsburgh PA
    I scanned it last night and there were no codes. I bought a new samco tbb put it on and its doing the same exact thing. As for a smoke machine I do not have access to one. anyone else have any ideas. i really appreciate everyone's imput so far. thanks
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Check the boost guage lines....you could just have a leak with that; possibly giving you bad boost readings.
    Veteran Member Three Rings S4NIK8's Avatar
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    My 2000 is actually doing the same thing right now, no boost leaks and the vagcom says its asking for 18psi but only getting 14. I was thinking a bad N75 might do this?
    Jul 28 2010
    Pittsburgh PA
    I will check the boost lines but I guess the only thing left to think of would be a bad boost gauge. That doesnt explain why im gettin 0 boost reading in first gear or sometimes it goes to 7 psi. Really stumped. I read another post where a guy thought that a temperate change might have something to do with it. Im not totally sold on that tho.
    This might sound like a stupid comment. Where the hell is the N75??
    Veteran Member Three Rings ski&drive's Avatar
    Feb 22 2010
    00 S4
    Metrowest Boston
    Quote Originally Posted by doublebogey2 View Post
    If your referring to me im pretty sure its not a ambient temp problem... however the n75 is on top rear of the passenger side of the engine under the engine cover. Symptom of a bad n75 are fluctuation in boost which sounds like could be your problem.
    Established Member Two Rings RitchS4 914's Avatar
    Sep 29 2008
    Yonkers NY
    What dv's are you using ? If stock that might be your problem also.
    Jul 28 2010
    Pittsburgh PA
    Im using apr dvs. is there any way to check the n75 to see if its bad. im not saying your wrong i am just wondering why its not showing up on a vag com.
    Jul 16 2009
    Having a similar problem, good luck.
