Results 1 to 14 of 14
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    Lubromoly or Motul 8100
    Hey guys.
    I searched different forums and I can't find if anyone has ever compared the two oils. Up until now I have been using Lubromoly 5w-40 and it's been running fine. It costs about $36 per 5 quart jug, which is somewhat reasonable for what is considered a good oil. Much better than the Mobil 1 oil it seems from all the tests reviews I have been reading. Anyways, a good friend of mine who owns an Euro auto repair shop started ordering large quantities of Motul 8100 Xcess oil and he can supply me with it for about $19 per 5 quart jug, about half the price of the Lubromoly. The Motul 8100 sells everywhere online for $47-50 for a 5 quart jug so I am definitely getting a good deal but is the oil better than the Lubromoly? I know Motul for their great gear oil and brake fluid but not too many reviews about their engine oil. I have their gear oil in my car and I can't complain but they are too different substances so one can be awesome and the other one complete crap, although I doubt that's the case here.
    Right now I have 7 quarts of Lubromoly for my next oil change and also 7 quarts of Amsoil synthetic oil that I got to try out, even though it cost me $9 per quart. I am set for my next two oil changes but since I will be installing my brand new BW K04s to replace my crappy RP K04s I want to make sure I give the BWs the best oil in this price range, especially on priming and the initial start up with the first few thousand miles. I will probably use the Amsoil for that but want to stock up on oil for the future at this great price if it's worth the money.
    I hope someone has tried these oils and can share some observations and impressions.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Jun 14 2007
    2000 S4
    Connecticut
    I'm going to help you out and post this on bob is the oil guy forums...They will help you out being that oil is what they know best!
    Around here it's all opinion, but watch for their answers. They will be talking about where the oil comes from and stuff that you never even wanted to know about oil.
    Link to the thread I made on BITOG
    May 31 2009
    CA. USA
    Thank you very much for doing that. A lot of responses in a short time for sure. I guess I should pass on the Motul oil for now, unless my friend can get me the X-max.
    Thanks again for doing this.
    Veteran Member Three Rings eboosted's Avatar
    Jul 17 2009
    lima
    Just saw this post.
    The difference between X-CESS 5W-30 and X-MAX 5W-40 is the amount of additives making the X-CESS much better option, nevertheless both oils have type 4 API bases. I think the X-MAX 5W-30 is already out of the market however there's a new formula for the X-MAX 0W-40 but it hasn't been approved by AOA yet.
    The X-CESS is an awesome oil, much better that lubro-molly synthoil which is nothing special but an expensive price tag.
    Another option is the Audi Specific option from Motul, it's basically an X-CESS with more additives to comply with Audi standards, this is what I'm ussing at the moment, coming from Castrol Magnatec and Lubro-Molly I can tell you it's a whole new world at a very good price.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by eboosted View Post
    A whole new world?
    I'll be honest, I've been using LM 5W-40 for nearly 10 years now... I used it while i was living in Germany, and I've continued to use it on all my "good cars" here in Canada. None have ever given me an issue, none have felt better or worse then any other good oil out there (GC, Mobil, Motul, AMS Oil, etc) and a UOI on my 2.7t w/ LM verifies this.
    So if you could please clarify why using your preferred oil is better then others that would be great, along with UOI's showing a difference.
    Jul 17 2009
    lima
    Hello Notorious:
    Lubro-Molly synthoil 5W-40, which I think it's the one you've been running for the past 10 years, changed his formula like a year ago in order to comply new standards, it used to be a group 3 oil now it's a group 4. Motul X-CESS has been manufactured as a group IV oil and it's the only one made with esters technology, they have an specific oil as well wich complies with VW 502 standards.
    FWIW I'm not saying Lubro-Molly is crap, I just wanted to point out that there are differences worth mentioning between Motul and others manufacturers.
    BTW there IS a world of difference between group 3 and group 4 oils.
    Jan 29 2009
    The European version of LM 5W-40 is Group IV based, while apparently in the US it's Group III (HC stock)... that said... my UOA was from 2 changes ago and had great results even then so I'm not too sure about them changing their formula especially since I can't seem to find any evidence supporting your claim on BITOG either.
    Jul 17 2009
    lima
    No problem.
    As far as I know, esters technology has been patented by Motul, some other manufacturers claim to have the technology as well but they aren't exactly esters but additives that try to simulate the oil adherence, this will give you much lower wear on cold starts.
    As I can see this the Motul is a much better oil specs wise, this is why...., I made a mistake about the Motul X-CESS, it is not group IV, it's group V (not a point of comparison with group III oils) so the bases from what the oil is made are much better, it means that it works better in severe heat, keeps viscosity under extreme conditions longer and has a higher TBN (controls corrosion better) this could extend the service interval without having to change the oil that often.
    It doesn't mean other oils will blow your engine up, but with the X-CESS you will have lobger service intervals with better wear protection and a bit better performance.
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Lubro-Moly. Use it in every car I work on and every car I own. Its constantly moving over here. Its a great oil. Castrol, Mobil 1 etc dont compare.
    Motul I have no first hand experience with at this time but for the money and considering your car is not a race car Motul is really not needed IMO.
    Jul 17 2009
    lima
    Quote Originally Posted by *Blue-Angel* View Post
    Motul has a race oil as well, unlike the x-cess the race one has double ester chain and it's not recomended for daily drivers. I'm not sure how expensive is Motul in the USA though.
    You guys should give it a try, I'm pretty sure you will find surprising results between UOAs from both oil samples
    Sep 11 2007
    Tampa, FL
    I know that. Thats why I am saying I wouldnt put Motul in unless it is a race car. Their is nothing wrong with Motul but the price for the oil that you guys are talking about right now does not out weigh its benefits over Lubro-Moly. That is a fantastic oil.
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    You can get 7 quarts of the Motul X-cess 8100 and an oil filter from JHM for under $60
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Sep 11 2007
    Tampa, FL
    Was just going off the prices above. I have never looked into it as I have been happy with the performance of Lubro Moly, but then again I pay 5 a qt for it.
    Senior Member Two Rings tekazgtr1984's Avatar
    Oct 31 2011
    '95 BMW 740i
    Winnipeg, MB
    LubroMoly Synthoil 5W-40 in both my cars. Love the stuff.
    '00 S4 6-spd
    '95 740i
