Great responses fellas, now were getting somewhere.
Originally Posted by
dougyfresh
WHY is everyone making a custom TIP for this manifold? I thought a TIP was already designed and ready for sale with the downpipe?
Why Maestro? There are other options besides Maestro.
I was not aware of a TIP from PSI. Then again Jeff and I have not really got into the nitty grity, more overall talk. If one is available I will be getting it from Jeff. Why Maestro, well It will allow me to tune my car how I want to, with whatever turbo I end up with, or switch over too. It will also alot me to adjust my maps. to what I would like, when I want too. I will also be learning quite a bit while doing this, and It's something i have an intrest in and would love to take the time to learn about tuning ect. I plan on loging my car every day and making adjustments as needed. The goal of this build is not just to make my car faster, but to learn as much as possible, learn how to build a motor/take one out, and to learn how to tune a car.
I have learned quite a bit thus far with this car, and it will continue to be a learning experence. Yes, I could screw somthnig up with the internals of the motor, or with the tune, but I am willing to take that risk. If I can get everythnig back together and tuned properly, myself, then it will be of great satisfaction to me. Knowing that I built a car, and tuned it, and it runs well and is powerful and strong/reliable, then whats better than that?
Worst case scenario, I blow a motor b/c I built it wrong, or I blow a motor because I leaned it out to much or something like that haha. Either way I'll just rebuild and try again.
doublezero30
i would highly recommend upgrading the brakes. stock brakes suck even with a stock car. my b5s4 setup was night and day difference. and some people even recommend going bigger.
Thanks for the input Nate, I think I'll end up with some b6 S4 brakes, or a 350x35 mm Porche BBK. Not sure yet on how much I want to dump into brakeing, I know the BBK will be more for looks than anything else, but there is a chance that my car will start to see the track this summer and the BBK will be of use then to reduce and or eliminate fade.
BAB1990
AMB Head why? Don't make the mistake many have done, use an AEB head.
Why the AEB pistons? The only advantage is that they are forged. I would suggest picking up a set of JE if you are looking for a forged piston. Otherwise, remain with your stock pistons - just re-ring them.
You say you are going to use the N75 but than claim you are going to use a forge MBC. Don't use both, stick with the N75 and using Eurodyne you will be able to map your car much more efficiently.
Speaking of tunning, what do you plan on running? I would suggest Eurodyne, for $900.00 you can't go wrong.
AEB pistons - 20mm wrist pin, good to do if your going around 400whp. I could end up there so why not do it? Why not JE? They are $500 vs. the $150 I can spend on a set of AEB pisons. Why AEB head, well A. I have an AWW head curently, I want an audi head. B: I want to stay small port, no need to go large port where I am going to be for power. <450wheel even w/ a 30r. I will be running both an N75 and a MBC to limit boost to 20psi. With the Revo 550 file I'm not sure If I will be able to limit boot electronicly. Even if I can do so, I would want to MBC as a safety.
As I said above, I will be running the Revo 550 file. Then switching to Maestro.
PRY4SNO
Not to pollute your thread with a n00b question, but what needs to be done to the AMB block to fit 20mm vs. 19mm wristpins on the rods?
Nothing, just a larger wristpin which will require the appropiate rod at the least you would want to hone the cylenders for the new pistons.
vdubjetta02
I know its completly different, but i ran a 20g on a 2.0l Subaru and it didnt even hit full boost till around 4000 RPMS.....i can't imagine the 1.8 from Audi spooling it any earlier
This is deffinitly relivent to this thread. As this prove that the 20g can spool ~4k rpms. Now even though the 1.8l has less dispalcement, we could make the arguement that the PSI manifold flows better than the one you had on your car.
What manifold did you have? If it was a tubeular manifold then it would hit full boost later, as the runners are longer and it will take a higher RPM to spool a turbo, but you will of course get more top end.
