    Jul 28 2010
    2001 S4, 2006 A3, 2006 Touareg
    Pontiac, IL
    vibration while cruisimg.
    I get small vibration while cruising around 70-80. If I accel no vibration, decel it vibrated. It's also in intervals. It vibrated for about 10-15 sec, then goes away for about the same time and comes back.
    Veteran Member Three Rings Congratulati0ns's Avatar
    Nov 09 2009
    tri-state
    tires balanced? i use to get the same thing at around 60 until i got new rubber and balanced it
    6 Speed Single Turbo S4
    Q7 TDI S-Line
    Jul 28 2010
    Pontiac, IL
    I just got the vibration. But I can have that checked out, maybe I will get the tires rotated and balanced.
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    Do you have stock wheels? If not, could be because your wheels need hub centric rings.
    Veteran Member Three Rings AutoUnion1's Avatar
    May 28 2008
    Bronco, Q3, Alfa Romeo
    Michigan
    Might be a vacuum leak if occuring during decel. Tires at 60-70 is a good place to start but I'd also do a pressure test and check for leaks in the vac lines.
