Before I go tearing the front suspension apart (would be my 1st time), was wondering if you guys could make sure I'm off in right direction.
Have a very bad clunking sound up front upon the slightest road undulations. Issue has been going on for some time, but was rather low-key until I recently put on my winter tire setup last week. Same USP OEM 18" rim, worn summer tread swapped off for new winter LM60 Blizzak @ local Discount Tire.
Clunking sounds somewhat similar to when I first had the suspension installed (incorrectly). Top mount strut bolt was not properly tightened and mechanic had to re-do install. Car is lowered on Vogtlands (~45k miles ago) and have driven rough CO roads for last 35k. Car has 95k, 60k of which was driven in San Diego. Still original control arms.
Is this plan of attack reasonable?
1. Check/tighten front sway-bar end links (2 weeks ago was on mt dirt road with high speed/small bumps of death)
2. Check/tighten control arm bolts
3. If no dice with 1&2, remove strut and check/tighten top oem strut bolt.
4. If no dice, remove strut again, use new bushing/top strut bolt.
5. If no dice, change control arms.
6. If no dice, drink self out of pain and bring to a shop.
Anything else basic I'm missing?
Any idea why clunking could become so much worse after new tread install? Weight of tires within a 1lb of each-other (new vs new spec). The old front tires, however, were worn to belts on insides. Car is sitting noticeably higher now due to high side-walls of winters.
Any input appreciated. Thanks!
