Results 1 to 18 of 18
    Sep 22 2010
    Sask, SK
    Cool B7 Key on B6 Complete / Need Programming for Key Fob
    Team B6 A4,
    I recently purchased this B7 Key:
    http://cgi.ebay.ca/02-03-04-05-AUDI-...item1e5ef0af08
    I Spoke with a bunch of locksmiths to find what everyone finds "we dont cut steel keys". After everyone told me this i got rattled and drove down to a shop. I showed them the key and explained that there are people in the world who cut them and I want to know why he can't. He explained steel ruins the machine so I asked if it was possible that the blade was copper. He brought out a magnet, and sure enough it was not steel, all Audi keys are made from a copper material which is cuttable.
    I then purchased a Key Reader from Ebay to read the B6 "SKC" (Secret Key Code) in which I used to program the Key with my Vag Com so that the immobilizer would be accepted by the car.
    Does it work is the question.... YOU BET IT DOES.
    Now here's the problem:
    I read over 10 different method's of programming the key so that your "unlock/lock" and functions work. After trying a ton of em, i am now left with my 2 regular keys, my new B7 key ... ALL OF WHICH do not operate the locks. So I am driving with either my B6 or B7 key fine but cannot operate the fob functions.
    Can someone out there explain the exact procedure to follow so I can program these things again. Also any questions about the B7 Key will be followed up on.
    Thanks Team.
    Veteran Member Four Rings ocod's Avatar
    Feb 17 2009
    05 A4 1.8TQM, 05 Nissan Xterra, 99 Sea Doo Sportster
    miami
    sorry bud.
    you brought the wrong pn.
    It needs to be 8EO and ends w/R or L
    KO4 APR Stage II+ // tt injectors // Podi SW gague // NGK BRK 7E .28 gap // 2.5" Test Pipe // Forge 007 DV //
    APIKOL Snub Mount // Stock N75 // 20%Tint // DTH FRP Skirts // 270 miles to empty // B7 key fob // 35W 5K HID's
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    have you got a link for the key reader you bought
    i sync the keys by
    turning the iggnition on dont start the car
    press lock unlock
    remove key
    should work
    Feb 17 2009
    miami
    Sep 22 2010
    Sask, SK
    Quote Originally Posted by ocod View Post
    sorry bud.
    I just opened up my Factory 2003 A4 Fob and it reads 8Z0 837 231 F .... 315MHZ ... and after checking the Ebay link again, is the exact same model. So this is not the problem
    Sep 22 2010
    Sask, SK
    Quote Originally Posted by bez101 View Post
    i sync the keys by
    press lock unlock
    remove key
    should work
    The product you want is "Vag Key Login" or an even better version for more is "Vag Key Com+Can V5.05" both found on Ebay or on Google by many sites, I ordered mine from Hong Kong. Be prepared to wait 3 wks.
    Feb 17 2009
    miami
    Quote Originally Posted by TrooSyreen View Post
    thats good then. there is another pn that works.
    Keep trying then.
    the instruction on how to program are in the link i posted. Sometimes method described above works other times not so much :)
    Sep 22 2010
    Sask, SK
    Ok cool, maybe the only thing im missing is the Vag Com Programming (Step 6 from the link you posted which I will post below). Once I have this working I'll create a step by step process to convert your B6 -> B7 Key for roughly $100 total cost as a DIY without any steeler involvement.
    Heres the step I am probably missing:
    6. Keymatch remotes using Vag-Com:
    Again, go to this thread http://www.audizine.com/forum/showthread.php?t=199643 or follow the below:
    Start Vag-Com
    Choose [46 - Comfort System]
    [Adaptation - 10]
    Go to channel 021.
    [Read]
    * Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory positon 3).
    [Test]
    * Now press any button on the remote you want to match.
    * The meas. block field above will change from Not Recogn. to Recognized.
    [Save]
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    I'm interested in that eBay key reader...details?
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Sep 22 2010
    Sask, SK
    I ordered the "Vag Key Login" found HERE
    Plugs right into your OBD2. Just as if you were plugging in a Vag Com but the "guts" inside the cable are designed to only read the SKC code and adapt new keys. So basically you fire up the program, read your ECU and within 5 seconds you have your SKC code. From there you have 1 other option which is "adapting keys" where you can add/remove keys that have been programmed to your car's ECU.
    Fairly easy to navigate, I'm actually shocked how many people don't know it exists.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    dude...change the crystal over from your old key. it doesn't matter what code the new key is. plug and play.
    Sep 16 2010
    Central Wash
    Thumbs up
    Kudo's to you for finding a tool that reads the Immo box on the b6- as long as your car is 03' and later, you've found the grail! I Sent you a PM. I knew there are about a hundred different tools that claim to read the SKC from the 03'**> audi, but never felt like tossing $150 out the window to find out if they're honest.
    and...Yeah, actually I think it's been said but that particular B7 fob might not match with the B6 system. I don't think the CCM has the instructions written in it to look for the signal that remote sends, even though it IS 315mz. You can actually look in the VCDS measuring blocks and press the button on that remote and see that the signal IS or is NOT recognized, I had one of those and an *8P0* fob. Neither ever worked, but if its an *8E0* ending in 'R' or 'L' it does. It'd be nice if you did get it working...but I never did using the same process that DID work for the 8E0 remote.
    Jun 30 2008
    Erie, Pennsylvania
    Very interested in the immobilizer programming. Would love to see some screenshots and instructions for that part. I wonder why vag-com can't pull the SKC and this software/device can.
    Just 1 question about that. Did you need your current, working, transponder key present in order to program the new one? Or could you have started the car with just vag-com, key reader, and the newly cut ebay key?
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    I'm the author of the DIY referred to in post #8 above. Obviously, the procedure I outlined for synching the keys worked for me. The other DIY referred to above gives the proper key part #'s that will work on the B6. I'd check your key against this list.
    Very interested in the SKC reader. I'd like to be able to program more keys. I'd also like to try and see if I can get a color cluster I have to work in my car. I know you need the SKC to reprogram the cluster with the existing mileage from the old cluster. Perhaps diagnosticator can chime in here?
    Active Member Two Rings henriquevr's Avatar
    Oct 11 2010
    Sunnyvale / California
    To program the buttons on the key fob you will need original key and new key no vag-com needed. for immobilizer you you need more tools as you already know and have done it.
    Back to the first part.
    To program the remote functions on a new key, get in your car with the car off and the driver side window rolled down.
    insert the new key into the ignition
    insert your vallet key in the driver side door lock (outside the car)
    turn the vallet key towards lock and hold it there
    while it is held towards lock, press the unlock button on your new remote for
    2 seconds.
    let go
    press it again for 2 seconds
    let go and you should hear an alarm honk or something like that.
    This is from memory so it may not be right. I would recommend searching web a little more.
    Sep 16 2010
    Central Wash
    All the tools generally work the same- but Ross Tech purposely doesn't include Eeprom reading and writing functions in their tools because people can really mess stuff up. And the ability to read the SKC and adapt the Immo system is something only the dealer and some high-end locksmiths have legitimately. The tools you get for $50 or $100 from china are 100% Pirated and sometimes don't work at all. Someone from Ross tech may chime in..they're everywhere!
    And I think Ross Tech, being a legitimate company prefers to operate on U.S. soil, and offering a tool that allows anyone to roll their odometer back and meddle with immobilizer functions would get them in trouble I think. In china..I don't think anyone cares...seeing as how you can buy an Iphone in a vending machine.
    As for programming the key, you usually just need 'all' the keys you want programmed, so if you have extras, do them all at once- at least that's how VCDS typically works. If you just try and do one new key, you usually just have that one key adapted..meaning all keys must be adapted each time you adapt ANY key. BUT! Some of these programs have a button that says "make key", you click it and you're done, new key adapted. So, yes, if you can manage to adapt one new cut key that has a proper chip then you can start the car.
    Sep 22 2010
    Sask, SK
    Sep 16 2010
    Central Wash
