Results 1 to 8 of 8
    Senior Member Three Rings jeradw's Avatar
    Jul 18 2009
    2008 A4 (his) 2010 Tiguan (hers)
    Wisconsin
    Part Number: Rear View Mirror (B7 w/ Ti package)
    Title is pretty self explanatory...looking for the P/N for the rear view mirror to fit a B7 with the Ti package - basically to get a black rear view.
    Thanks guys!
    -Jerad
    2008 Tip A4 Special Edition - Brilliant Black
    18" Enkei EKMIII Gunmetal (summer) // Hyper Silver (winter) | 35% Tint | Eibach/Koni FSD Street Kit | de-Badged
    AWE Diamond Black QuadTip | Blackout S-line Grille | Ti Trim | Color Matched Front Reflectors | Smoked Side Markers
    Front Filler Plate (Black) | Plastidip'ed Trunk Strip (Black) | K&N Drop-in | APR 93 Stage I
    Jul 15 2009
    CA
    Here are the part numbers for the mirrors from the dealer I work at;
    8D0-857-511 A 4PK $159.60 - Mirror w/o compass & auto-dimming
    8R0-857-511 A 4PK $729.75 - Mirror w/ compass & auto-dimming
    Hope that helps you out. If needed I can see if I can get it @ employee cost which is Cost + 10%.
    Jul 18 2009
    Wisconsin
    Thanks!!
    Edit: I'm sure this is ok, but ECS says "Up to VIN #1-003200, split is in model year 2001. Only fits Coupes" Still going to be ok for my B7 Sedan?
    Senior Member Three Rings crew's Avatar
    Oct 02 2009
    1966 Mustang, 1988 F150, 2006 A4 2.0t (SOLD), 2013 Focus ST
    I disassembled mine, plasti-dip sprayed, and put it all back - black rearview! I'll post pics later when I can (I'm at work).
    I used vinyl dye paint previously, but I need to get more and re-do this..
    -Matt
    Quattrophenia (PSN)
    flickr
    MTN Custom Leather
    Jul 18 2009
    Wisconsin
    Nice...thats a good idea. I never thought about plastidip! I have a half can left over anyways.
    Oct 02 2009
    Make sure you do enough coats (I only did one, but they said 3-4 is ideal).. otherwise it may scratch too easily.
    I did vinyl spray dye last time, and it worked like a charm. Hardest part is disassembly, but definitely worth it compared to taping off everything. If you have a thick guitar pick, or those cell phone opening tools, they'll work like a charm.
    The face (where the mirror itself is) clips into the rear part, so wedge whatever you're using into at the seam wherever you think will be least noticeable - in case you end up scuffing it a little - and apply pressure at an angle like I drew below. Be very careful working your way in and taking it apart or a few will break. I'll take pics next time I open her up.
    -Matt
    Quattrophenia (PSN)
    flickr
    MTN Custom Leather
    Jul 18 2009
    Wisconsin
    Quote Originally Posted by crew View Post
    Thanks for the heads up!
    http://www.audizine.com/forum/showth...earview-mirror
    Quote Originally Posted by ApexIt View Post
    didnt you have to turn it something like 90 degrees counterclockwise and then pull off?
    In regards to removing the mirror from the windshield...do you think this sounds about right?
    Oct 02 2009
    Quote Originally Posted by jeradw View Post
    Yeah, that's about right. Use constant pressure and grip the base (not the mirror!) near the windshield, and turn it counter clockwise. You'll feel it give a bit, and once it's turned about 50 degrees, it'll feel loose, and it will just pull free. You can then disconnect the harness for auto-dim, and remove the mirror!
    You can remove the base (the part that looks like Dark Helmet's helmet) from the mirror assembly, it's just a plastic cover. Once the mirror is apart from the windshield, pull out on the edges of that base cover and push it away from the mirror base with even pressure. It slips right off - you can look inside and see the clips, just be careful not to break them. I'll post pics of all this, and a DIY, next time I take it all apart.
    -Matt
    Quattrophenia (PSN)
    flickr
    MTN Custom Leather
