    Feb 09 2007
    00 S4
    MA
    limp mode, smoking on decel....
    welp some new problems since H20....
    My car is overboosting (~23psi on APR), and will go into limp mode if I am at low RPM's and high boost. so I can still pull through 1st and 2nd, but 3rd is too high a load and it goes limp.
    also, i am getting some white smoke, only on Decel, and only after pulling through gears. it did this before the limp issue, but it is definitely now worse.
    I pulled codes, and the only one that concerned me, besides a positive charge deviation code (limp mode) was an EGT code, drivers side.
    So normally I would just order a new one and throw it in. but the code has changed over the past couple days.
    it started as a "short to ground" code, then a "implausible signal" code, now I cant get it to come back. should I go ahead and order it?
    I have a DYNO day this sunday, so any and all help is appreciated.
    also, my mods are:
    APR chip
    Dahlback DP's with custom testpipes
    ASP cat-back
    deleted N249
    deleted secondary o2's
    deleted EVAP
    710N's (brand new yesterday)
    SAMCO TBB
    TIA!
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Senior Member Three Rings Aureus1's Avatar
    Feb 06 2010
    06 Mustang GT, 2006 F350 Diesel, 1997 Jeep Grand Cherokee, 2012 Focus SEL Hatch, 1991 MK1 Cabriolet
    TheCommonWealth
    Just do a VR6 swap, I'll help you on Saturday...
    "You love your car as much as you hate it..." - my GF
    GSE www.granitestateeuropean.com
    Team Sad Panda
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Have you pressure tested?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Feb 09 2007
    00 S4
    MA
    yea pressure test was good, no leaks, did it twice.
    I ordered the EGT anyway, and got it today, ill see if that works.
    Feb 09 2007
    00 S4
    MA
    EGT senser stopped a significant amount of smoke on decel. but didnt do anything for the limp issue.
    BUT, I pressure tested it again, and my passenger side wastegate line has a leak :( anyone have any suggestions one which hose I should use and tricks to make it easier? I know it can be done with the motor in.
