Results 1 to 7 of 7
    Veteran Member Four Rings Rocs's Avatar
    May 25 2009
    Audis
    Conshohocken, PA
    Divertor valve? What is the purpose
    I see a lot I threads on divertot valves. What are they? What do they do? What's the purpose?
    I'm on my phone so I can't search. Thanks for the help
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    takes excess boost and reroutes it back into your TIP. Similar to a blow-off valve, but it doesn't put the excess air into the atmosphhere.
    Hooray for boobies!
    May 25 2009
    Audis
    Conshohocken, PA
    What is a tip? Are they functional? How much are they usually
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    RIP QG TI B7 A4
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    the TIP is the turbo inlet pipe.
    if your car is stock you don't need to screw with it. if you are running more then stock boost then you shoudl upgrade the DV since the s5tock one can't handle the 3x increase in pressure that a tuned flash does.
    May 25 2009
    Audis
    Conshohocken, PA
    Thanks for the help. How come I see some guys who's cars are stock upgrading Their divertor valves? Is it just so their car will sound like they have a blow off valve?
    Dec 18 2007
    nj
    reason to replace the DV on a stock car would be because the original one is damaged or you want to prepare the car for a flash. if you want more sound you need to change to a BOV, but a BOV on a stock car is like having a HUGE hood scoop that isn't connected to anything. not to mention a BOV releasing 8psi would sound like ass.
