Results 1 to 21 of 21
Thread: chips
    Active Member Two Rings f3racer's Avatar
    Oct 03 2010
    Lebanon MO
    chips
    i have searched the forum quite a bit and see alot of apr and giac reflash stuff. what about this? anyone used it?
    http://www.jetchip.com/shop/shopdisp...sppp=10&vall=1
    US Army Military Police
    10 Cobalt
    03 Explorer
    07 CBR 600 RR CCS racer #81
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    The new lays balsamic and herb are the bomb
    Veteran Member Three Rings AdamS4's Avatar
    Feb 05 2006
    Chicago, IL (Western burbs)
    Dude, call up Prince at Vast and get a custom tune. They made my K03 S4 run amazing.
    ****sell me your li s4/toy guy remote v1 display!!!! *****
    2001 Casa - PJKO4s/Vast /AWE Twin 1/jhm shifter, ERs
    Oct 03 2010
    Lebanon MO
    well being where i am a plug and play is probably the only option for me. i am probably getting the apr flash, but i was just curious as what the opinions were of jet's stuff. custom tune would be great, but doesnt that require the car to be on the dyno?
    10 Cobalt
    03 Explorer
    Feb 05 2006
    For plug and play, commonly called OTS (off the shelf) around here, APR and GIAC are popular options.
    A custom tune doesn't require dyno time. Many guys call up site sponsors like EPL or Vast and work the tuner on a certain type of file. I told Vast I wanted a more "conservative" tune and they worked with me and developed a file which fit my needs. For example I specified exactly what peak boost I was comfortable running and also got a stock program loaded on the ECU. When my needs changed they were able to code out the rear 02s and change other parameters of the tune.
    Bottom line is I was very happy with the results and feel the tune was a tremendous value given the cost of OTS chips around. Often there are forum members with software who will help you take logs and send to the tuner for file revision.
    Feel free to PM me with any more questions. Make sure you address common failure items such as the TBB, DVs and any boost leaks before chipping. Get a boost gauge and possible a new N75 before chipping the car.
    Senior Member Two Rings schusters4's Avatar
    Dec 13 2007
    Portland
    I had GIAC before and threw CEL's all the time for misfires.....Jet I used for my Toyota 4runner. I didn't know they made chips for Audis. Looking to get the APR chip for my next S4... along with their components..
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    Really depends on what you want. I know that a GIAC X K03 car will blow the doors off many other tunes, but it comes at the cost of your turbos. Also, from what I hear, power delivery is not very linear, and is rough. I mean, they are fast, but they essentially hold 20+ psi to redline. KO3's cannot safely hold that much boost, and will eventually cook the seals, and bye bye turbos. As for APR, I think they are more conservative, and they are a very solid choice because you have the assurance that what you are getting is good. I am running an MTM. Very Very Very Very smooth power, lots of low down torque, but it falls on its face past 5300 rpms and is certainly not the fastest. I've heard good things about ASP software also. Its totally up to you. Just depends on you priorities. I have been thinking a lot lately about getting a custom tune to be conservative, yet a bit stronger than the MTM.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    Go APR if you want your car to run good, go custom if you want your car to run great. All cars are made different and will perform different with OTS tunes. Since your asking here is our input, but its your car go with whatever you want.
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    Quote Originally Posted by Turbo Nerd View Post
    what do custom tunes generally cost? Say from EPL or VAST? If I wanted, could I call them, tell them where I want boost to taper and stuff like that, and they could just flash my ECU?
    May 12 2009
    Detroit Metro Area
    5-600 I believe, call them up and tell them what your trying to get out of your car. I can't really speak for them but it's best to call/email them and see what they can do for you. Also anyone that is a vast reseller can do revisions on your car (as long as they have the cable). It's great because I'm 30min from vast, really a great company and a good bunch of guys.
    Veteran Member Four Rings mikehawk666's Avatar
    May 17 2010
    Colorado
    doritos cooler ranch
    '78 F350
    VW T3 tintop
    Mk2 GTi VR6
    E46 Touring
    Veteran Member Three Rings nkbks4's Avatar
    Mar 26 2009
    Silver stg 1 avant, Black 01' STG 3, wife - Honda Pilot
    Naples, FL.
    Quote Originally Posted by sherbet View Post
    giac doesnt see nor hold 20 psi. im selling a mbox ecu rite now that only hits 18psi, matbe 19 on a good day. then falls to 14psi.
    but yes, my turbos only lasted a yr w/ giac and meth...
    Stg 3 black sedan 395whp/402wtq (sold and will be missed)
    Silver stg 1 avant cleaner upper
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Veteran Member Three Rings spokismB5S4's Avatar
    Jun 06 2009
    01.5 S4 6mt, 03 RS6, 91 coupe quattro, 12 STI, 02 S6 01E, 97 328is w/6266, 87 325is, 86 325e
    Quote Originally Posted by f3racer View Post
    Really?
    Anchor Audi Technician
    DM Technik Tuned BB 2001.5 S4 6mt ** ER's, Rostens, Frankenturbos, Tubi Mani's...
    Ben Swann Tuned Black 1990 200 Turbo avant 5mt ** Turbo-xs Bov, Cherrybomb, Catless...
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    OP, you should get one of these! I hear great things
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Utz Darks.
    I have an old GIAC 93 chip somewhere if you are interested.
    No ECU, just the chip for cheeap.
    Veteran Member Three Rings Congratulati0ns's Avatar
    Nov 09 2009
    tri-state
    Damn that makes me worried...my revo hits 21 and holds 18 to redline...power delivery is smooth except the fact that everytime it will hit 21ish...then drop to 15-16 and right away go back up to 18. Idk why it does that
    Veteran Member Four Rings sqitis's Avatar
    Sep 03 2010
    B8.5 S4, B7 Avant S-Line, 8v A3 SLine
    Nashville, IN
    I've got Stratmosphere and it really flattens out after initial boost. My buddy also has Revo/K03 and his car is ridiculous when compared to my tune. I can't wait to get another ECU so I can go Revo!
    Established Member Two Rings B5//S4's Avatar
    Nov 05 2009
    SL,UT
    Call Prince at VAST! Best possible option. With OTS "doritos cooler ranch" you cant go back and say "can you adjust this chip to be a nacho cheese flavor?"
    May 12 2009
    Detroit Metro Area
    ^nice
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by Congratulati0ns View Post
    Your car is probably boost leaking, or has some other problem. Maybe a bad boost regulation (n75) valve. Try an H-version n75. They work better with holding boost on aftermarket (aggressive) software.
