Results 1 to 19 of 19
    Jan 01 2009
    fairfax va
    So can you add navigation to a 2009 Audi A4 that doesn't have it?
    I bought my Audi A4 in 2009 and did NOT get navigation. Does anyone know if you can actually buy it aftermarket to fit right where the screen is now? Or is that impossible b/c the car doesn't have the buttons already in it. Has anyone tried this? Instead of a garmin, etc.
    Thanks all
    Mike
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by levishness View Post
    Thanks all
    Mike
    It is pretty much too complicated and to expensive to be feasible... You have to completely install MMI...
    You have to install the nav components in the trunk, replace the head unit in the dash, change out the screen, add the MMI buttons, and rewire everything for fiber MOST...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    Roger - DavidB8 has a wiring harness he picked up for a few hundred $$ iirc. That is just the basis, the 3rd gen MMI is the backbone of the Nav system, its not just a head unit replacement.
    My suggestion - get a nav program for your smartphone if you have one. If not, just get a Garmin unit.
    "A man who won´t die for something is not fit to live." - MLK Jr.
    Active Member One Ring kepiting1sg's Avatar
    Jan 23 2010
    Audi 2010 A4 2.0 TFSI Quattro, Mercedes Benz W212 E250CGI, Toyota Prado 3.0 TDI
    Singapore
    Yes! U can!
    I have done the mod on my A4 with an after market Multi Media Interface
    You can add an after market Media Interface eg like XCarlink.
    http://www.xcarlink.co.uk/product.ph...3&cat=4&page=1
    The media interface will sit between your Symphony/Chorus/Concert HU and the stock OEM LCD screen.
    The cable going to the LCD screen will be plugged into the after market MMI.'
    The after market MMI will come with a similar cable to be connected to the stock screen.
    With the after market MMI U can add a host of items for eg. Garmin GPS GVN53, Reverse Camera, DVD Player/Changer, Digital DV, etc.
    Changing of the different screens i.e Stock Displays, GPS, DVD, Digital TV, etc. will be as if like oem by pressing & holding the Mode button on your steering.
    The only thing U lose will be your auxilliary input.
    The auxilliary input will be the sound input(DVD, Digital TV) from the after market MMI to your sound system
    For better resolution for your Garmin GPS GVN53, U need to make a RGB cable to connect to the after market MMI which provide a RGB input for GPS Navigation.
    The GVN53 will come with a Radio Hz Remote Controller - IMHO though clumsy in the beginning but will be a breeze once U get used to it.
    The GVN53 will come with an external speaker and provide the sound for Navigation. In this way U can still listen to your radio, CD, DVD while on the move.
    The GVN53 takes a SD card for your Garmin Maps
    https://buy.garmin.com/shop/shop.do?cID=134&pID=10573
    The reverse camera will be switched on to your stock screen whenever U reverse.
    Any after market reverse camera can be fitted - They are usually in NTSC format.
    Here are some pictures of my installs! Hope this helps!
    The Garmin GVN53 Black Box size is small 4.7"W x 1.18"H x .4.6"D
    The GPS antennae located on the left hand corner of the windscreen. Heavy tinting of your windscreen might have to locate the antennae outside your ride
    The familiar Garmin GPS Start Screen
    A typical GPS Map View - Turn by turn & TTS (Text To Speech) Available. GPS Audio is by it's own speaker box. This way U can still listen to music with the stk system
    & still has GPV Navigation at the same time.
    Digital TV reception & picture quality is pretty good especially on the highway even at high speed.
    All screen changes on the MMI is via the Mode button on the steering wheel
    On my setup the screen changes OEM **> Garmin **> AV1(Dig TV) **> AV2(DVD/USB) **> AV3(iPod/iPhone)
    Reverse cam is turn on by reverse gear regardless of what screen U are in.
    Reverse Camera from Alpine - Picture quality actually looks better than in the photo - Very clear
    iPhone/iPod Dock - charger & capable to play music through the car stk sound system or play movies thru the MMI.
    Playing Songs or Movies from USB drive that came with the DVD Player
    Watching DVD
    Dec 03 2015
    Atlanta, GA
    Tons of Thanks
    Tons of Thanks for the information.
    I just got 2015 Audi A4 without Navigation system and any other features. Kind of disappointment sent in with empty screen for no use.
    This gives me a great relief. I will try.
    Quote Originally Posted by kepiting1sg View Post
    Watching DVD
    Feb 01 2010
    Canada/India
    this is an excellent set-up. any chance you have installation pics? also can you put up some pics with a not so close up view. Thanks!
    Nov 26 2010
    Belgrade, Serbia
    @kepiting1sg
    Thanks for the very useful information.
    Did you tried to install touchpanel and connect it to GVN53?
    On the display from reversing camera from Alpine I can see that there are 'guidlines' on the display itself. Does moving the steering wheel has an effect on those, and how is the camera connected to the system?
    Also when you say that you change what is on the display with MODE button on the steering wheel, are you talking about original mode button or some addon? Also, how is that button connected to the aftermarket MMI?
    Veteran Member Three Rings Cherub's Avatar
    Jun 20 2010
    Golf-R
    FL-Global
    Nice set up man. Sounds like a DIY project that is well wroth the $ and learning experirence.
    MK7.5 R Daily
    B9 S4 (Pending Sale)
    2 B8.5 & B7 - Sold
    Tints & More..........
    Veteran Member Four Rings promoda's Avatar
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    I also have the XcarLink im able to connect my iPad to it and use the Navigon App to direct me..works perfect!
    Active Member One Ring B8Ziner's Avatar
    Sep 30 2010
    Vancouver
    Is that an iPhone holder ? where did you get that ?
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    nono, I bought an xcarlink adapter, which allows you to use you stock Audi screen as a monitor ex: dvd plater, tv, back up cam... using component wires the same you would on a regular TV. I bout the apple av cables and connected my iPad to the carlink and now what ever I see on the ipad is displayed on the car screen. works perfect. i watch movies (when parked) use the ipad navi to get to A-B, installed a back up cam that turns on as soon as the car is in revers... a worth while mod for your car, if you spend a lot of time in it...
    Established Member Two Rings lphiewok's Avatar
    Dec 31 2009
    Los Angeles, CA
    I have one with touchscreen. total cost was $650 plus for Touch Screen NAV + Reverse Camera and additional 150 for DVD player.
    you can search a thread on it (it's from Germany. I know about 3 others on this forum who have installed it).
    I did install myself and although it took few weeks to get everything worked out, it was not that hard to do. And I prefer mine over xCarlink because I can use my screen as a touch screen (you have to place a glass sensor which is taped on top of original AMI screen but not noticeable)
    2010 Audi A4 B8 Premium Plus.
    Current Mods: LED Interior Conversion. LED License Plate. Hoen Xenon Match Fog Lights.
    Trunk Lid Spoiler. Chrome Grill Inserts. Hardwired Valentine 1. VAG-COM. E-codes Headlights, Touchscreen NAV / Reverse Cam / DVD Player.
    Glossy Black Plate Delete. Gunmetal S5 Rep. 245/35/19. ST Coilovers.
    Jun 14 2011
    Bayside, NY
    Touchscreen Question
    Quote Originally Posted by lphiewok View Post
    Hi,
    I just got an audi A4 2009 and I'm looking into installing a nav system like the one you described. I have so far not been able to find a solution that supports touchscreen and I was wondering if you could let me know what system you used. A link, model name/number, or any information you might have to point me in the right direction would be great. Thanks.
    Nov 22 2015
    MA
    I'm in the middle of installing a similar unit. Unfortunately, it doesn't look like it was getting power so I reinstalled the original, but now the original display won't power up either. All the fuses look fine. Any tips?
    Quote Originally Posted by promoda View Post
    Nov 26 2010
    Belgrade, Serbia
    @overjagi:
    This device is pretty good find... I'm using xcarlink+viseoo bluetooth+garmin gvn53, but the one you listed costs much less and provides much more...
    If you have troubles with the iGo maps, you can always install Garmin software on the Windows CE based device..
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    I know this is an old thread but just found it. Is there a way to dock an android phone to the xcarlink so that way i can use that as my GPS?
    Established Member Two Rings B8Nate's Avatar
    Dec 21 2015
    2012 MK6 Jetta S
    Little Rock, AR
    I got an iPhone 6 Plus (the big one) use "maps" app and turn it sideways and let it rest in the MMI display area. Boom factory installed GPS hahaha no seriously, that's what I do on trips I need GPS. I have a usb thumb drive with all my music on it. So I got music and directions.
    B8 A4 Quattro | Meteor Pearl Grey | K04 Turbo | Carbonio APR Intake | APR Catback | APR Turbo Muffler Delete | Forge DV | APR Downpipe | KW V1 Coilovers | Rotiform SPF 19x10 +35 | S4 Tie Rods | Rieger RS5 styled Front Bumper Conversion | Rieger Rear Diffuser | Rieger Side Skirts | Carbon Fiber Duckbill Spoiler
    Veteran Member Three Rings Steelerhater37's Avatar
    May 29 2017
    BMW E36(98)M3 convertible//VW B6(07)Passat
    Bel Air Maryland USA
    Check it out
    [QUOTE=levishness;5779025]I bought my Audi A4 in 2009 and did NOT get navigation. Does anyone know if you can actually buy it aftermarket to fit right where the screen is now? Or is that impossible b/c the car doesn't have the buttons already in it. Has anyone tried this? Instead of a garmin, etc.
    Thanks all
    Mike[/QU
    Senior Member Three Rings yma4's Avatar
    Dec 27 2011
    San Diego, CA
    Overjagi - great article! Thanks for the post! I've been looking all over for something like this (I have an '09 a4). If it's not too much to ask, could you reply/pm me with more details on the product (ie. level of install, total cost, etc.) If you pm me id be happy to exchange emails/phone #'s. Any help is VERY much appreciated!
