Results 1 to 7 of 7
    Mar 22 2010
    03 SILVERADO SS TOO MANY PARTS TO LIST, 2001 SUBARU OUTBACK (ONLY ECONOMICAL CAR)
    Salisbury NC
    infinity kappa speakers with bose setup? aftermarket amp or stock one??
    i have a 2000 audi s4 with stock bose symphony sound system. my bottom driver in my passenger door finally blew so i will be replacing the speakers. i was told the easiest replacement while keeping stock bose head unit and amp are to replace the bottom drivers with 2 way speakers (must be 2 ohm as the amp powers it this way). the only 2 way speakers i could find are the infinity kappas (the infinity reference are now only 4 ohms). i was told these will pop right in and are better than the stock bose and even better the infinity reference. my real question comes into play is that the stock bose amp might not be able to power these speakers enough to really hear the quality instead it might sound worse if there isnt enough watts going to them. will this stock amp be suffice or do i need a bigger speaker amp? if so is there anything that will directly bolt in? i am not looking to change the head unit as i already put the ipod adapter in and i am not looking to rewire the whole car. all info appreciated. also i was told from crutchfield that the front doors are 4" and the rear doors are 3.5". is this true? other ppl say that its 4" and 5.25". i need the DOOR SIZES NOT THE SUBS IN THE REAR DECK. i already ordered the 3.5 and 4 i really hope these are correct.
    Veteran Member Three Rings spokismB5S4's Avatar
    Jun 06 2009
    01.5 S4 6mt, 03 RS6, 91 coupe quattro, 12 STI, 02 S6 01E, 97 328is w/6266, 87 325is, 86 325e
    I have the kappas with the stock head unit in the rear deck. They sound great so im sure that those should work just fine. GL
    Anchor Audi Technician
    DM Technik Tuned BB 2001.5 S4 6mt ** ER's, Rostens, Frankenturbos, Tubi Mani's...
    Ben Swann Tuned Black 1990 200 Turbo avant 5mt ** Turbo-xs Bov, Cherrybomb, Catless...
    Veteran Member Three Rings B5SilverS4's Avatar
    Oct 15 2006
    02 Porsche 911 Turbo, 94 Mercedes E500, 14 Porsche Cayenne GTS, 91 BMW 318I, 05 Mercedes CLK55 AMG
    Charlotte, NC
    I thought the rear doors were 5.25s but then again we may have made adaptors when I use to install car audio for a living.
    Also, what IPod adaptor did you go with?
    2016 Audi S8 Plus
    2014 Porsche Cayenne GTS
    2005 Mercedes CLK55 AMG Black on Black, Kleemann, Renntech, BBS, Bistein, etc.
    2002 Porsche 911 Turbo Lapis Blue Metallic, BBS LMs, H&R Coilovers
    1994 Mercedes W124 E500
    1991 BMW 318IC (E30)
    Sold - 2008 Mercedes CLK63 AMG Black Series
    Sold - 2013 Audi S6 APR, HREs
    Sold - 2001 Audi S4 Nogaro Blue w/Black interior, APR, Stasis, BBS, etc.
    Sold - 2003 Audi RS6 Daytona Gray Pearl w/Platinum interior, 10SecS4 Tune, MTM TCU
    Jun 14 2007
    2000 S4
    Connecticut
    Go to crutchfield.com, they tell you all the specs of the stock system you'd like to know...
    www.crutchfield.com
    Senior Member Three Rings Audiophyle's Avatar
    Jun 24 2009
    ABQ NM
    Infinity calls them "true 4ohm", which actually means 2ohm at the coils. They will work.
    Unsure why they started this, its confusing to everyone but the idiots who were previously confused about what a 2ohm driver was.
    Front doors are components with a 1" tweeter & 4" midbass.
    Very few companies offer a 4" comp set, and even less at 2ohm(if any). A 5.25" set will fit with very little extra effort.
    The rear doors are 6.5" midbass (no tweeter), same size as the rear decklid subs, but different speakers altogether.
    00 Hibiscus S4 Tip
    Mostly Stock...... for now
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    about to pull the trigger on the 6.5" infinity kappa 2 way rear deck speakers... the "true 4 ohm" stuff is retarded, just to clarify these are 2 ohm speakers and are plug and play correct?
    '17 Ibis White B9 A4 quattro P+ S-Line
    Jun 24 2009
    ABQ NM
    Yes, however the rear deck speakers are subs, so keep that in mind when replacing with a coax.
    00 Hibiscus S4 Tip
