Results 1 to 7 of 7
    Senior Member Two Rings Trotter715's Avatar
    Apr 05 2008
    New Jersey
    if this friggen thing beeps one more time!
    my stupid cluster keeps saying that my coolant is low and beeps three times. than it shuts off. than it does it again. and again. and again. and, well you get it. IM LOSING MY MIND!!! i cant drive anywhere anymore. There is plenty of coolant in the car so i dont understand what the problem is.
    Does anyone know how to disconnect the cluster? Or sensor? Or both? anything to make it stop!
    Pleaaase get back to me people.
    PS i searched!
    I'm a dog chasing cars, I wouldnt know what to do with one if I caught it.
    Jun 30 2008
    Erie, Pennsylvania
    Did you check the connector on the bottom of the coolant bottle? Maybe it is just loose. I'd unplug, clean the contacts and plug it back in. Make sure it clicks.
    Basically, the cluster beeps when it sees that circuit go open. Open = no continuity = no coolant = beeping. It sounds like yours is an "intermittent open" as you get the warning off and on, otherwise it would just beep once then the graphic would stay on constantly.
    Other than a loose connector, the possibilities are:
    - Faulty sensor in the bottle
    - Faulty wiring
    - dirty connector (corrosion)
    - faulty cluster
    I believe you can eliminate the bottle as a possibility by just jumping the connector with a paper clip or piece of wire. That should close the circuit permanently. If it still goes open at that point, you have a wiring or cluster issue.
    Most likely is just a loose or dirty connector at the bottle. Definitely check that first.
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    - Faulty wiring
    - faulty cluster
    I would also jump the wires on the sensor, if cleaning the contacts doesnt work. Just have to keep an eye on your coolant, in case it really does go low one day.
    Hooray for boobies!
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    like said above, check the plug underneath the tank and check if its pluged....if it is...fallow above steps
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Apr 05 2008
    New Jersey
    alright i checked the connection under the tank, cleaned it, and its still going off. this may be a stupid question considering every response commented on it, but how do i jump the sensor?
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    you need a new coolant reservoir, something is wrong with the float sensor in the reservoir, there is two wires on the connector...jump is by connecting a wire to both of them and you will be done
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    How do you jump the relay? i need to do that to my Washer fluid one.. one of the rubber gaskets on the seal are shot so its always slowly leaking out lower then the sensor and then stays lit on the dash. I guess i should really be fixing the leak before the bad weather comes this year because they load our roads with sand n salt, and they keep saying its going to be the worst one in 40 years..
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
