Results 1 to 10 of 10
    Established Member Two Rings geebesRS4's Avatar
    Apr 14 2010
    2007 Daytona Gray Audi RS4 / 2009 Exile Cycles Bullfighter / 2005 Dodge Ram 1500 / 2010 Honda CRF250
    Anyone sold their DRC?
    Hey guys, just had the Stasis Motorsports installed on my RS4 (amazing BTW) and was wondering if anyone has tried to sell their DRC suspension? Mine is brand new as I just had the recall done about a month ago and maybe have 800 miles on it. Even has new supply lines. I know I probably won't get much, but more or less want it out of my garage. Any input would be appreciated, thanks!
    Mar 11 2008
    B7RS4 & e46Ms
    I got a couple hundred bucks for mine before the recall letter was sent out. I'd say these will begin to appreciate post-Jan 2012...
    FRRG AZ Ring
    Senior Member Two Rings salmjo1's Avatar
    Feb 11 2005
    Lynchburg, VA
    I put stasis on about 3 years ago, before the DRC fix. I ended up throwing the original stuff away. When the recall came, they wouldn't replace mine without old parts to turn in, so I had to buy a set of PRE-recall shocks to get the upgrade done.
    Current:
    2011 S4 Sprint blue/panda, 6MT, Prestige w ADS. AWE exhaust and intake, Brembo 380 BBK, Alu-Kreuz, SRP pedals, VAG'd, Nurburgring sticker.
    2008 RS4 Cabriolet, Imola, PSS9s, Tubi.
    1983 Ur Quattro
    2007 RS4 Sprint Blue
    2004 S4 sedan, 6sp, Nogaro, milltek, PSS9s
    Plus 3 allroads of various flavors...
    Active Member Two Rings petercw2's Avatar
    Sep 08 2009
    '80 CJ7 (original owner)
    Dallas
    Quote Originally Posted by salmjo1 View Post
    So, you took off the Statis and put back on the DRC "C" upgrade? If so, why? And did you sell the Statis setup?
    '07 RS4
    '07 s/c RR
    http://www.audizine.com/gallery/data...afsfrontSM.jpg
    Feb 11 2005
    Lynchburg, VA
    I pulled the Stasis as the recall was done, then I sold the car and bought a cab. I moved my Tubi to the cab, and have the Stasis sitting on the garage floor. I just had the cab DRC recall done which was a HUGE change on that car. I had been considering putting the Stasis on it, but will not now as I am very satisfied with the stock suspension considering the way this car will be used (obviously zero track time). The suspension will need to be rebuilt and sold.
    Current:
    1983 Ur Quattro
    Oct 11 2007
    Suburbia
    I agree, Rev C is very good for a stock suspension. OP, you prob won't get more than a few hundred for the stuff.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~
    ~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Bilstein PSS9s~Girodiscs~JHM shifter~
    01' A4 Silver 1.8T Avant 5MT
    ~Motoza Ko4 tune~550cc injectors~Apikol SMIC~3" testpipe~ST coilovers~18" Avuses~
    In, Out and Around...
    i will have a complete system with pumps for sale soon after i upgrade to coil overs. waiting for january/february. no point doing suspension mods to lower the car before winter. i am building a fun car, not a snow-plow.
    Veteran Member Four Rings Retsujou's Avatar
    Dec 07 2008
    08 RS4 Tit/Exec/Prem/Carbon
    Mississauga
    Quote Originally Posted by petercw2 View Post
    DRC gets upgraded to revision B/E in the recall. C/F is the Sport Suspension Plus.
    08 B7 Cherry Black Pearl RS4 + JHM Lightweight Flywheel + JHM Stage III Clutch + VAST Piggie Pipes + K&N High Flow Airfilter + APR Stage II (Testpipe tune) + Hueper Optik 30% + Magnaflow X-Pipe + Centre Resonator Delete + Deflap + HAWK Ceramic front/rear + Stoptech Steel Brake lines + V4 LED Headlights (blackout/clear corner)
    Oct 11 2007
    Suburbia
    Quote Originally Posted by Retsujou View Post
    Difference being shocks and springs only?
    ~Maxton Aero bits~
    i think 22mm rear sway bar as well.
