Results 1 to 33 of 33
    Jul 14 2009
    Pasadena
    single vs bixenon
    I made this thread to dispel any rumors made about the pro's and cons of each of these projectors (I am talking ECODES in specific)
    so, besides the fact that:
    bixenon ecodes
    -clearly have larger projectors
    -less pronounced glass mold lines
    -side placed city light(stronger high beams?)
    -rear mounted ballast
    -o ring problem(simple fix)
    single ecodes
    -have a more condensed light
    -more pronounced glass mold lines
    -bottom placed city light
    -bottom mounted ballast
    -better cutoff
    what are the other major differences?
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Veteran Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    Wondering the same thing.. subscribed
    -Andrew
    Frankenturbo/GIAC
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Ballast is located in different positions. No other differences
    Dec 06 2007
    ecode single xenon has a much crisper cut off and the best beam pattern of all the headlights available for our cars.
    The bi-xenon is not as crisp, I have the S4 bi-xenons which are fairly similar and they aren't crisp, they look more foggy and smooth not sharp.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    I saw you bought those ecodes in the classifieds. Deal of the week.
    Dec 06 2007
    ^^he literally bought them behind my back Tu. I had already made the deal too. Matt is just straight buying up the market.
    -Kirk
    Jul 14 2009
    Pasadena
    Quote Originally Posted by AudiA4Turbo22 View Post
    really kirk...
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 06 2007
    Quote Originally Posted by itsmatt33 View Post
    really kirk...
    Lol Matt, just pulling your leg.
    -Kirk
    Jul 14 2009
    Pasadena
    i figured. hahaha :p
    can we get oldguy or diagnosticator im sure those guys have an amazing answer
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 07 2009
    East Coast
    Doesnt the single xenon come with wider lens as well? I'm pretty sure I came across those....
    Forget the B8, keep the V8!
    Jul 14 2009
    Pasadena
    Quote Originally Posted by Mr.Wrong View Post
    i dont think so. i posted a pic so u can compare the two
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Mar 01 2010
    Farmington Hills,Mi
    Amazing answer for what? AudiA4Turbo22 described the light output and u described their physical difference. What else do u expect?
    Jul 14 2009
    Pasadena
    Quote Originally Posted by BASARAB View Post
    theres much more to it then that.
    for instance the bean pattern, which is different in the bi xenon as they curve upward to illuminate street signs(or so im told)
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Aug 26 2005
    The only thing I can add is the Bi Xenons either DOT or E code, are effected by the vertical adjuster shaft seal O ring issue. (That I originally discovered.) That is the cause of the water leak into the housings and the lens condensation that frequently occurs.
    Vorsprung durch Technik
    Dec 06 2007
    ^^I have that problem too.
    -Kirk
    Sep 27 2007
    Boston, MA
    Kirk, you have a lot of problems.
    Jul 14 2009
    Pasadena
    i thought this was a simple fix? swapping a o ring?
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Jul 14 2009
    Pasadena
    okay guys so i think this info thread is pretty much complete i hope it helps in the future
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    i have oem bi xenon hids lookin fore ecodes but only come across single xenon will i be dissapointed?
    Jul 14 2009
    Pasadena
    Quote Originally Posted by BerNur View Post
    not exactly each headlight housing has its pros and cons. the bi xenon have a greater light dissipation but the single xenons have a really condensed light beam.
    either way youll be happy.
    this thread should give you all the info you need
    ***forgot to mention im currently running single ecodes and the light output is amazing
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Mar 01 2010
    Farmington Hills,Mi
    I have not run bi, but single xenon e-codes are fantastic, they give a very wide and sharp light output.
    Jan 31 2009
    so single is the way to go im sorry i have no experience with this as my car came with stock bixenon
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    I ran ecode bi-xenons for 3 years. Switched to ecode single-xenons in 2007. To my eyes the single-xenon's low beam is better. Although I do miss the bi-xenon feature... 2-3 times a year.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    if your avatar is your car then you dont have bixenons
    Jul 14 2009
    Pasadena
    Quote Originally Posted by Kwarner View Post
    his projectors actually look pretty big bt its hard to tell in the tiny pic
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 06 2007
    this thread is so useless SEARCH for crying out loud.
    Let this thread die matt. You already got the answers.
    -Kirk
    Aug 26 2005
    That is correct. The replacement O ring needs to be a tighter fit on the shaft and the bore for the shaft.
    Veteran Member Three Rings AvantinUSP's Avatar
    Jul 28 2008
    Quote Originally Posted by Tgr_Clw View Post
    Same here. went from OEM single to ecode bixenon then to ecode single. the single by far has the best cutoff. I also saw some yellowish tinting on the edges of the cuttoff when I ran 6k bulbs with the bixenons.
    Jan 31 2009
    you think so my paperwork says bixenon.. il take a closer pic tomorrow to post up.
    Sep 06 2009
    Bay Area
    i was just lookin at your avatar, judging by your profile picture im wrong.
    Veteran Member Four Rings Raiketsu's Avatar
    Jan 21 2010
    '10 Marin Bobcat Trail
    University of Georgia
    Kind of a random bit of info, but I have the single xenon Ecodes, and with my 55w 6000K HID kit it lights up every reflective surface. Even beyond the actual light. It's pretty awesome. I can see signs and stuff before the light even hits them.
    Amulet Red 2003 Audi A4 1.8T
    Ecodes, Trunk Lip Spoiler, K&N Drop In Filter, LED Interior Lighting, DDM 55w 6000K Lows and H9 Retrofitted 2500K fogs, Depo LED Tails, painted brake calipers, and some VAG COM Mods
    Established Member Two Rings Xmenpl's Avatar
    Nov 25 2009
    Long Island
    NA bi-xenon + 55w hid + Clear Lense (ZKW) = money
    It has very sharp blue cutoff, i could snap some photos if anyone is interested.
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    ^^Which lenses did you get, and where did you order them? And how was the installation?
    -Andrew
    Frankenturbo/GIAC
