Originally Posted by
NickZag
My tires are fairly decent (Pzero Nero) but I do tend to get some understeer on the track which I believe would be corrected with a larger rear anti-roll bar. Your call correct, I called my dealership and they said the S4's anti-roll bar is the same size as the one on my Sports Package. Do you guys think the 28mm Stasis is overkill compaired to the H&R?
If you are tracking regularly, the RSB will help eliminate the turn-to-turn shift of weight, but does almost nothing for understeer. You need better tires and/or tighter springs to compensate for the heavier bias of the A4 in the front. My stock tires gave up more quickly than true track tires, but with better tires, I know (and instructor noted) that the understeer would be drastically reduced.
Also, if you are tracking on 19s over 18s, you may want to go back down a notch to allow more roll in the tires on corners. Those with less sidewall have almost 0 tolerance before breaking loose from the pavement. I saw it a number of times at our event, including a Porsche GT3RS running on 19s (he is having 18s fabricated for his car for better grip (and they are cheaper)).
