Results 1 to 4 of 4
    Established Member Two Rings Galvez987's Avatar
    Nov 12 2009
    2010 Audi A4 2.0T quattro, 09' Porsche Cayman PDK
    Atlanta, GA
    A4 B8 AWE quad tip exhaust
    Will an AWE dual outlet quad tip exhaust fit on a non-sline A4 B8 with a Bastuck rear valence??
    I've been trying to find the answer all over the forum, but no clear statements...maybe I suck at searching....
    Veteran Member Three Rings John4378's Avatar
    Mar 19 2009
    Houston, TX
    If you can fit a Bastuck quad-tip exhaust on a Non S-Line car using their valance, then the AWE quad-tip exhaust should fit. The only fitment issue would be laterally in order to center the tips and make sure they fit within the cut-outs of the valance.
    AWE just says that their quad-tip system will not fit on any non S-Line car because of the valance issue. Audi does not make a non S-Line valance for the A4 that supports a dual outlet (or quad-tip) exhaust. That doesn't mean that an aftermarket valance won't work.
    I guess the bottom line is to contact a Bastuck representative or distributor and ask them. That way if it does not work on your car Bastuck shouldn't give you any crap about returning the product.
    Dearly Departed - 2008 A4 Avant 6MT S-Line w/ APR Stage 2, 034 HFC
    2006 Lotus Elise
    2005 Ducati Monster S2R
    2006 Ducati Monster 695
    2009 A4 6MT S-line w/ APR chip, AWE exhaust, AWE FMIC, Eurocode HFC
    2011 Ford Explorer - Family Swagger Wagon.
    Mar 02 2007
    Fresno, CA
    As far as I know, nobody here has done it. The best I can tell you is try and see for yourself. Bastuck did not design their valence based on the A.W.E. exhaust and vice versa. However, that does not mean they aren't compatible. I can only assume that since Bastuck doesn't sell a valence for S4/S Line cars, they designed their exhausts to work with the S4 valence, so fitment should not be a problem. Go for it!
    Nov 12 2009
    Atlanta, GA
    Thanks a lot for the info guys! Do you know if the heat shield from the S4 fit my A4? I've heard of some guys that have done it without the heat shield but I would rather play it safe.
