Results 1 to 7 of 7
    Jul 27 2010
    Singapore
    "Standard" S4 B8 suspension code 1BA or 1BD/1BE?
    I have been wondering about this for some time now. Are S4 B8 guys in the USA running 1BA standard running gear code on your car sticker or a 1BD or 1BE?
    I ask this because I was under the impression that the A4's run 1BA and the S4's are already lowered and running 1BD or 1BE. Or, is there no 1BD/1BE for S4 because 1BA (stock) is lowered and that's what appears on the sticker?
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    I can check my sticker and see if you, in the US the S4 is supposed to be lower than stock A4 by 20mm or something I think.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Jul 27 2010
    Singapore
    Quote Originally Posted by NWS4Guy View Post
    Yes, that would be great. Just want to get a better understanding of the B8's. Thanks!
    Veteran Member Two Rings droidakty's Avatar
    Mar 03 2004
    2010 S4
    My S4 has 1BD on the sticker
    Using the online options code decoder
    http://igorweb.org/equidec/Default.aspx
    1BA = Standard suspension/shock absorption
    1BD = Suspension/shock absorption for special sports design
    1BE = Sports suspension/shock absorption
    Jul 27 2010
    Singapore
    So am I right to assume that 1BD is standard for S4 B8? And there is probably no 1BA base option?
    Quote Originally Posted by droidakty View Post
    Sep 29 2009
    Quote Originally Posted by S5noob View Post
    I believe so, I forgot to dig my sticker out last night to verify, but I think 1BA is stock A4, 1BD is S4, and 1BE is A4 S-line.
    Jul 27 2010
    Singapore
    I think you are right.
    And 1BL is ADS, and 1BV is the lowest (S Sport suspension by Quattro GmbH).
    But it would be nice to confirm without a doubt that there are no 1BA S4's.
