Results 1 to 14 of 14
Thread: Motor mounts
    Veteran Member Four Rings Duchenbagen's Avatar
    Feb 29 2004
    ATL/FLL
    Motor mounts
    My second B6 is a USP wagon primarily driven by my girl friend. It's an APR K04 car dsmic and exhaust. It had a bad motor mount on the passenger side of the car. I used 034 Motorsport's motor and transmission street density mounts. I run them in my sedan and like them. She is not loving them. I can understand it does vibrate a little more than the stock mounts and also transmits more sound through the car's subframe. So here is my question. What can I upgrade to that will not be as harsh, but still offers a gain from stock? I am looking at B5 S4 or RS4 motor mounts, and B7 RS4 transmission mount. I know that the motor mounts will work. Does any one know it the B7 RS4 trans mount will work? What are you guys running and how do you like them? Also, there will be a set of 034 motor and trans mount in the classifieds with 200 miles on them soon.
    -John
    John
    USP CLUB MEMBER #5
    How much does the illusion of integrity cost?
    Oct 09 2008
    I absolutely hated my 034 motor and tranny mounts. (Street density on motor and track on tranny). Vibrated way to much. I would look into the RS4 motor mounts.
    The Awesome™
    Veteran Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    try the V6 3.0L mounts for the B6 on your 1.8t (cheap and better thant OEM 1.8t mounts)
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I like my 034 mounts, but never drove an avant with them. I would be interested in the Transmission mount since I haven't done that one yet.
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Why not just go OEM? They're nice and soft.
    CEO and General Manager of the AZ Pedal Responce Team
    Feb 29 2004
    ATL/FLL
    Quote Originally Posted by Elliott View Post
    Like I said, I want some improvement over stock. There is way too much slop in the drivetrain.
    John
    USP CLUB MEMBER #5
    Sep 09 2009
    Arizona
    I have the 034 motor mounts on my car with no vibration. I have the street density, with a neuspeed snub and stock tranny mount. It did take time to adjust both the motor mounts and the snub to get everything working properly. I had the motor mounts done at a local Audi shop because I was concerned I would not be able to adjust them correctly, but when I go the car back it felt like I had a diesel under the hood. Turns out the "recommended" Audi shop I had mine installed at did not even adjust the snub after installing the new motor mounts. I would double check fit, and make sure everything was done properly. There really shouldn't be an increase over stock, otherwise just go with OEM I don't think the RS4 are worth it.
    Feb 29 2004
    ATL/FLL
    Does anyone know if the B7 RS4 transmission mount will work with the 1.8T 6speed transmission?
    John
    USP CLUB MEMBER #5
    Feb 29 2004
    ATL/FLL
    Quote Originally Posted by AZUltra View Post
    I have the 034 mounts in my sedan, like I said. There is an increase in vibration and sound. Not unlivable for me, just not comfortable for my girl friend. I understand too, it makes the Avant resonate when you are coasting and the steering wheel and pedals vibrate. So I am going to change them with something that suits her needs better. I call it noise abatement.
    John
    USP CLUB MEMBER #5
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    Quote Originally Posted by pape View Post
    X2
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Are u sure its adjusted on there correctly? And that u have the correct street density?
    My street density is sooooooth as butter.
    Only gets rough on cold motor and when blowby reduces the oil level by a 1/2 quart or so.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Sep 09 2009
    Arizona
    Quote Originally Posted by Duchenbagen View Post
    Haha...understood.
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    I'd go with B5 S4 engine mounts and OEM tranny mount.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Three Rings bl0wn3ur0's Avatar
    Jul 22 2008
    NY/PA
    i would suggest the B5 RS4 engine mounts. the S4 guys love them and they make WAAAAAAAY more torque than we do, i'm not sure if the B7 trans mount fits so i can't help you with that one.
