Tools Needed
- Jack Stands
- 21mm socket
- 13mm socket
- 7mm socket
- T27 Torx socket
- Flat Head Screw Dirver
- 8mm Allen socket
- Adjustable Wrench
- Phillips Screw Driver
- 3in extension
- 6in extension
- Rubber Mallet
- Brake Caliper retractor tool
I will assume that you know how to jack a car up and remove the rims.
Step 1 - With the tire off of the car, keep the emergency brake on and remove the screw that is holding the rotor in with the T27 torx socket. I made the mistake of trying to get this screw out after taking the cliper apart. This didn't work too well because the rotor spun freely. The screw is pretty rusted in so you might want to spray some "rusteze"(I really mean pb blaster) into it to get it out. Don't worry if you strip it or break the screw. You can drill it out easy enough and you don't really need to replace it. I broke 3 out of 4 trying to get them off.
Step 2 - You want to now release the emergency brake now. So you can release the emergency brake cable. Use the flat head screw driver to remove the small clip and remove the ball off of the mechanism. Once the ball is off, you can pull the cable down through the hole and out of the way.
Step 3 - Next use the 13mm socket and the locking pliers to remove the two bolts holding the caliper in place.
Step 4 - Slide the caliper off and rest it on something out of the way, while not putting too much stress on the brake lines. I used a 5qt oil bottle.
Step 5 - You can now see the brake pads. You can most likely remove them by hand, but worse case you can use the flat head screw driver to pry them off of the caliper carrier.
Step 6 - Use the 8mm allen socket to remove the top bolt holding the caliper carrier
Step 7- One of the biggest pain in the butt design is that you can't reach the bottom 8mm bolt without first removing the rear strut as well. Use the 21mm socket and an adjustable wrench to remove the bolt holding the bottom of the suspension strut. I had to loosen the 13mm nuts holding the top of the strut as well so that the strut had some play. Use the 6inch extension to reach them. My lower bushing was locked in place and I had to pry it a bit with my flat head for it to release the wheel hub. This allowed me to have the room necessary to remove the lower 8mm allen bolt.
Step 8 - Remove the 8mm allen bolt using the 3inch extension. This was a perfect fit.
Step 9 - Remove the caliper carrier.
Step 10 - The rotor should now be free of any obsticles from beting removed. It will not come easy though because of the rust. I had to slowly turn the rotor and hit it with a rubber mallet quite a few times for it to come loose. Be very careful with this. Remove anything underneath the rotor and certainly make sure there aren't any body parts near there when you are banging on the rotor. It will come loose with a few good wacks. I didn't move my screw driver when I was doing my front rotors and it fell on it and broke it in half.
Step 11 - Take a wire brush or something simular to remove any excess rust around the wheel hub. Install the new rotor with T27 torx screw if you didn't break it while trying to get it out.
Step 12 - Install the caliper carrier with the 2 8mm allen screws. The shorter one is on top and the longer one is on bottom.
Step 13 - Use a jack to jack up the rear suspension so that it'll line up with the rear strut.
Step 14 - Tighten the 13mm nuts at the top of the strut and then put in the 21mm screw underneath. Don't forget the large washer on the left side of the strut.
Step 15 - Take the cap off the brake resevoir (White container looking thing by the battery (I didn't know where it was either) don't forget to put a cloth around it just in case the brake fluid comes out), and use the brake caliper retractor tool to push and turn the caliper back. This will give you room for the new pads and new rotor.
Step 16 - Install the new pads into the caliper carrier and replace the caliper over top of it.
Step 17 - Put the 13mm nuts back on the caliper and replace the E-brake cable.
For the front brakes, I followed the steps on this page http://www.audizine.com/forum/showth...0+steps+brakes but I followed the steps on this link http://audiworld.com/tech/wheel137.shtml to remove the 2 7mm allen screws instead of the t55 torx screws. It's much easier. Here is my finish product of the rear and the front.
I hope this helps anybody who wants to do their own brakes and rotors. It wasn't too bad and took me about 3-4 hours with clean up.
Joshua
