Results 1 to 6 of 6
    Active Member One Ring DavidPdF's Avatar
    Oct 29 2008
    Billerica, MA
    Overheating problem
    The other day I got the low coolant warning light and topped off my coolant.
    After a few days my car overheated slightly (one mark over 12:00). When I stopped I noticed steam. When the car cooled off I added coolant and started to drive. Again I went on mark over 12:00 but when I turned on the heater at full blast it went back to 12:00.
    When i got home the coolant tank was cracked. I replaced it and .... same problem.
    Next step, replace the CTS and ... same problem.
    Seems strange because the heater can keep the temp around 12:00.
    Gets worse on the highway and better around town.
    Any ideas here I should look next.
    Established Member Two Rings BITURBOB5's Avatar
    Apr 24 2008
    01.5 S4
    Harrison
    Have you done waterpump?
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    also, make sure the hoses are all good, not cracked. The thermo. could be sticky, or the water pump could be shitty. The coolant temp needle should generally be right in the middle, dead center.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Check that this fan is coming on with the A/C
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Veteran Member Four Rings sqitis's Avatar
    Sep 03 2010
    B8.5 S4, B7 Avant S-Line, 8v A3 SLine
    Nashville, IN
    Sounds like stuck thermostat.
    Oct 29 2008
    Billerica, MA
    Timing belt was done at 80K before I had the car, don't know if waterpump and thermostat were changed. It is now at 100K
