Results 1 to 11 of 11
    Jun 04 2007
    Huntsville, AL
    DIY for Quattro Suspension Install????
    Did some research and have yet to find a good DIY. Anyone know of one?
    SoWo Presents The European Experience
    http://www.sowoeuropeanexperience.com
    Active Member Two Rings Lancek1028's Avatar
    May 22 2010
    Michigan
    2003 Audi A6 2.7T Quattro Tip Brilliant Black outside - Vanilla-Onyx inside. 18x8.5 VMR V708's 235/40/18 Bridgestone Potenza RE960AS Pole Position :APR Stage 1 ECU : Bailey diverter valves : APR Bi-Pipe : Magnaflow Catback system : Pro Dry Filter : Hotchkis, Tb/Wp Cam seals, crank seal, valve cover seals : GROM iPod Adapter Direct Interface : Adams Drilled and Slotted Rotors : Akebono Ultra-Premium Ceramic Brake pads:
    Jun 04 2007
    Huntsville, AL
    Thanks! Never checked out AW before only been on AZ.
    Jun 04 2007
    Huntsville, AL
    Never in my life has a suspension taken as long to put on as this did. AND I still have a knock up front after taking it off twice to make sure everything is tight.
    Veteran Member Three Rings in2thenightaudi's Avatar
    Apr 03 2008
    '03 A6 2.7T 6MT
    San Diego, CA
    Quote Originally Posted by Matt@H2OTuning View Post
    where exactly were your pain points with the suspension swap? what setup are you using?
    -Nick
    OEM + 03 A6 2.7T 6-spd APR, 2Bennett, ASP, JHM, Hotchkis, Southbend, Mangaflow, SuperSprint, VMR, and some home-brew goodies
    Jun 04 2007
    Huntsville, AL
    There is just a lot to take off to get to everything in addition to the creative manuvering to get everything out. I have done MK1, MK2, MK3, MK4, MK5's that took less than half the time to install. I am using the KW ST setup.
    Apr 03 2008
    '03 A6 2.7T 6MT
    San Diego, CA
    damn, that doesnt give me any confidence for doing mine then. ive had coils for awhile now and just havent gotten around to put them on. a local guy said he could help me out, we are just having a hard time finding a time we are both free.
    -Nick
    Senior Member Three Rings MartyinCO's Avatar
    Sep 21 2008
    Ducati Monster 900
    Thornton Colorado
    I installed my coilovers in my garage with hand tools an jack stands alone in 7 hours, easy as pie
    Jun 04 2007
    Huntsville, AL
    It took me about 9 hours to do.
    Veteran Member Three Rings jeffp477's Avatar
    Jun 09 2009
    1982%20porsche%20924/%2005%20VW%20Touareg%20V8/2018%20VW%20Tiguan/%2717%20Triumph%20Street%20Twin/82
    temecula,ca(socal)
    it took me 4hrs to put all 4, 1hr 30 min for one 1hr break, then from there the other 3 was easy.. i guess i got the idea real quick.
    but then again i did a lot of cars before different makes and model.
    also changed a military humvee suspension. i think that was the hardest one i did.
    -jeff-
    c5union
    DIY Audi
    Audi Tech and tips
    psn:jeffp0477 gt5 whore
    Jun 04 2007
    Huntsville, AL
    Guess I will be pulling the fronts back off of mine. I have a knock when the suspension travels.
