Results 1 to 3 of 3
    Registered User Three Rings GWerks's Avatar
    Sep 11 2010
    Grand Rapids, MI
    Bleeding brakes. Quick question!
    Okay, so I did rear passenger, rear driver, I'm on the front passenger. Is there an inside bleeder? I can only find one, don't know if it's inside or outside. It's on the top of the caliper.
    Established Member Two Rings alhoward101's Avatar
    May 15 2010
    Bmw 335is
    Atlantic City
    should be a 11mm or something about that size, bleed screw on the top of the caliper, like in front of one of the bolts, just bleed from there
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Quote Originally Posted by GWerks View Post
    There's just one bleeder screw on all the stock calipers. It's on the top.
