    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    Removing mirror caps?
    Advice needed on easiest way to remove the mirror caps. Have searched a bit but could not find anything really related to taking them off. I am wrapping them in vinyl today, and would like to do it with them removed for a cleaner install. TIA
    -Brandon
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Remove bottom screws. and slide black plastic plate out
    unclip mirror plate CAREFULLY, yes the mirror is clipped on. makes easy to remove caps.
    once you have the mirror face off you will see 2 other screw holding the housing to the car unscrew those.
    To remove caps
    Edit: Someone please correct me if im wrong. I did this a long time ago some memory is a little rusty.
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and C7 A6
    Byers Audi - OH
    Audi Brand Specialist / Social Media Manager / Spokesperson Byers Imports (Audi, VW, Porsche, Subaru)
    Current: B7 OEM+ and C7 OEM
    Previous: B5, B6, B6 USP All OEM+
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    Mar 31 2009
    NC
    Thanks for the quick response Joey. Got them off. Only had to remove the 2 bottom screws, pop the clips on the little plastic piece under the housingand slide it outwards, then the housing just "pops" up over the mirror motor assembly.
    Thanks J and K also for the links. I searched "mirror cap removal", "mirror caps", and something else but didn't find that last thread posted.
    -Brandon
    12.9@104mph
