Results 1 to 16 of 16
    Dec 05 2009
    New York
    turbo oil return seal DIY
    does anyone have one? searched google and here
    Veteran Member Three Rings ColinAndrews's Avatar
    Oct 29 2007
    Edmonton, Alberta, Canada
    Are you replacing the seal on the pan side or the turbo side?
    It's incredibly simple. I jsut did the drivers side on my car. The flanges on the pan side mount with a single 6mm Alan. On the turbo side there are 2 6mm alans. The turbo side you will have to purchase a new gasket from somewhere, and on the pan side it is just an O-Ring.
    All bolts are clearly visable although the pan side alan is a bit hard to get to. It's easier with a stubby wrench.
    Sep 11 2009
    NE
    Oil return is easy but I have a feeling that's not what is wrong with your turbo. If your turbo is spitting oil, we are talking internal seal which pretty much means you need new turbos.
    Dec 05 2009
    New York
    Quote Originally Posted by ColinAndrews View Post
    did you get to this through the top side of the motor or underside?
    Dec 05 2009
    New York
    Quote Originally Posted by julex View Post
    It is an extremely slow leak, internal seal would cause burning oil no? I am getting a silver dollar size oil spot under the pass side turbo after driving
    Sep 11 2009
    NE
    Quote Originally Posted by bps4 View Post
    It could be anything but the return line is the easiest to fix.
    Dec 05 2009
    New York
    Could you point me in the right direction on how to locate it? I've taken a cursory glance over the top back portion on the motor, but didn't see anything. I can't locate the source from underneath the car either. I've done my TB and other maintenance items, so I should be mechanically inclined enough to do it with some hints.
    Oct 29 2007
    LOL. Can you see the turbos from the top?
    The bottom.
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Climb under the car and look at the turbo where is the oil coming from, you should be able to see a trail of oil, if the middle and top of the turbo is dry and only the bottom near the allen bolts are wet then its most likely the gasket.
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Sep 11 2009
    NE
    Is it only the oil dripping that's the symptom or you're also getting burnt oil smell along with it?
    Dec 05 2009
    New York
    only dripping, and it only happens after running the car for a bit, after a little leaks and it is cleaned up, it stops leaking
    Sep 11 2009
    NE
    You took the belly pan off when investigating the oil leak I assume? If not, you will have to do that and go underneath the car to tell us where it is dripping from. Taking a picture would be the best.
    Dec 05 2009
    New York
    no belly pan on the car, here is a picture
    Sep 11 2009
    NE
    That almost looks like a power steering leak to me since the location you're showing is roughly in the middle of tranny. Could also the tranny leak but unlikely in this section. Can you take a white tissue next time you see it dripping and collect some and tell us color of it? See if it matches what's in power steering reservoir.
    Veteran Member Three Rings lbs4's Avatar
    Jun 14 2009
    01 S4.99 Grand Cherokee.89 240SX
    Vermont
    since your car is on jack stands already, start the car and look underneath. have someone turn the wheel if its power steering it will most likely leak. but anyways with it running you may see were it leaks from
    Dec 05 2009
    New York
    Thanks for the tips guys. I will try these suggestions out when i return home this weekend and report back
