So now that my block is
back at the machine shop... for the second time [more details below] and the car has been taking up valuable lift space in my garage I figured I'd post some updates and hopefully some useful info. during the build of the engine. So on to the fun....
First thanks to Kneel for supplying the donor AMB head, saved me a lot of searching and dealing with shady yards.
So, engine is out, disassembled and the parts list:
used head (Kneel)
JE Pistons 81.5mm
IE rifle drilled rods
Supertech Iconel Exhaust Valves (single groove)
Rod & Main Bearings
Some timing parts (belt, damper) old stuff only had about 15k on it
Oil Pump & chain tensioner
Gaskets, seals & o-rings galore
Found a local machine shop that has rebuilt a lot of 1.8t heads & blocks. After BSing with the owner a bit I found out that they are one of the main suppliers of remanufactured heads/blocks for parts stores in the Northeast. Had a little tour and they are very well equipped and knowledgeable. Look up Hunts Machine if you're in the capital area. Basically had them do a complete job on the head (clean/surface/valves), bore & hone the block, check & polish the crankshaft.
Got the parts back on 11/15, the head was definitely a few notches above what I've seen come out of other shops in the area. Nice n shiny...
I was able to save some $$$ by installing the cams and bleeding the lifters myself. Now here is where I found some interesting info. on the lifters that I have not seen here on AZ. Not sure how correct it is, but please chime in if there is alternate info available. The shop highly advised that based on remanufacturing many of the 1.8t heads, that I should bleed ALL of the valve lifters down. While the Bentley states just to leave them under valve spring pressure for 30 minutes, the owner of the shop said he has personally seen lifters stick pumped up too much and hold a valve off the seat causing you-know-what. I figured for the 2 hours I spent doing it... better safe than sorry ; )
Procedure is on VWVortex somewhere but abbreviated version without pics is: slam lifter upside down on a piece of wood until inside cup comes out. It is sort of a PTA, but you get the hang of it after 5 or so. It is held in with a c-clip and tempered so you cannot grab with pliers. Once you get the inside cup out, pull "top" out and pour out the oil... there is a spring inside.. don't lose it. Mine were in surprisingly good shape so I didn't bother washing all of them in the parts washer, just kept them on a clean cloth away from dust-grit etc. When assembling, I did one at a time to not mix up parts. Since the bore tolerance regulates bleed down rate, I'm sure they are graded when assembled at the Mfg. for a precise fit. After the oil is mostly out, you put the inner cup together again and relieve air pressure inside by gently depressing the check ball with a pick or small tool.
So I skimped on some pics, but basically assembly went straightforward. Had consistent .051mm clearance on all main & rod bearings- not bad for close to 90k. I splurged for a real ring grinder from some online dealer in Michigan or Ohio for like 30 bucks, well worth it. Set according to JE sheet. Got everything torqued correctly (big crank bolt is insanely tight to get that 90 deg. index)
Now for the bad part.... got the timing belt all set-up, went to turn the engine over with a socket, got 90 deg. from TDC and F***, metal-to-metal stopping rotation at 11:45pm.... : (
At first I thought I had royally screwed up the timing-hitting valve...nope. The pistons at BDC were only about half way up the stroke where it was stopping. Pulled the oil pump, timing belt, center two rods, to try to eliminate possibilities. After looking around for a bit I caught a glimpse of something that made my stomach drop... metal sticking out of the side of #1 cyl. FAIL! The bolt from the lower hole in the timing belt damper cylinder punched right into the cylinder. I did not sleep well that night... thought I put the wrong bolt in somehow from another ziploc bag and killed my block.
After rifling through my ziploc's, I've since found that all (5) bolts on the front were wrong when I took them out. Two for the tensioner, and three for the water pump. Whatever monkey at the dealer I bought the car from did the timing belt last, must have lost the bolts and put in some that "looked" right. They were about 3mm too long and had previously bottomed out in the holes cracking the cast... but not enough to punch through. When I torqued them again to spec, they just pushed the metal right out the back didn't even give any indication when tightening them. So... now I'll forever be paranoid about blind hole depths! Now the block is back at the shop to get a sleeve so I don't have to start over with another block. I'll update with some more assembly pics once it's back next week. TBC.....
