Results 1 to 9 of 9
    Active Member Two Rings henriquevr's Avatar
    Oct 11 2010
    Sunnyvale / California
    Main Seal... change it or not?
    If I am going to change the clutch flywheel and etc.
    Should I change the main seal or leave it alone?
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Mine started leaking around 70k miles... 2002 3.0. Might as well change it..
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Change it. It's cheap and easy insurance. You don't want to do the clutch again because of a dumb leak.
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Sep 12 2008
    South Central PA
    mine has 130k on it and I've slapped in 2 clutches without ever changing it. IMO, if its leaking, even in the slightest, change it. If its not, don't touch it.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Three Rings rbj325's Avatar
    Aug 12 2008
    Rochester, NY
    It's a PITA. Don't fix it unless it's broke. More times then not if you replace it and it's not broken you will put it in improperly and cause a leak.
    Plus after you change your clutch once you can drop the transmission no problem.
    E85!
    "I got four cylinders when I need them and four cylinders when I don't"
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    change it... it takes 5 minutes to install... and as long as you put it on right it will be cake to install. the plastic ring it comes with allows you to install it perfectly.
    cheap insurance. do it.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    As a former audi tech.. I say leave it, unless it's sweating. If it's not broke, leave it.
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Main seal? Is this the prop shaft seal or am I confused?
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Mar 31 2004
    CA
    Quote Originally Posted by pOrKcHoP07 View Post
    Rear main seal (crank seal) its behind the flywheel
