Results 1 to 18 of 18
    Senior Member Three Rings Silver Bullitt's Avatar
    Aug 01 2008
    is really messy.
    Wheels rub on new brakes
    I posted this in the wheels section too but I dont think it'll get much traffic there....
    I have a 2001 S4 Avant
    Ok So I have a set of 18x8 ET45 RS4 reps. They have 235/40 Michelin PS2's on them. I just put on some new Adams rotors with Akebono Euro ceramics.
    All sounds good except....With my old brakes I would rub a little bit if I hit a big dip in the road. on the drivers side it looks like it rubbed on the suspension (rub marks are on the inner 1/3 of the tire. On the passenger side it looks like it rubbed on the fender (rub marks on the outer edge).
    With my new brakes the front wheels wont turn now. Crap!
    One would think I need spacers (maybe 5mm) but if I get spacers wont my previous rubbing be even worse?
    Thanks for the help.
    Senior Member Two Rings tre-oh411's Avatar
    Mar 15 2010
    2010 BMW 335i
    New Jersey
    that blows. same thing happened to me. my problem was, wheel was too small for the calipers. and they rubbed along the insides of the rims.
    Aug 01 2008
    is really messy.
    Yeah mine are rubbing center spoke right on the caliper.
    Veteran Member Three Rings jesters22's Avatar
    Oct 14 2009
    new jersey
    i would think some 3mm or 5mm spacers would work. i no their are smaller then 3mm aswell..
    PARTING OUT A SILVER 2001.5 S4 PM ME FOR PARTS
    http://forums.vwvortex.com/showthrea...2#post83363922
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    get some 8mm spacers. not a big deal
    Veteran Member Three Rings B5stgIII's Avatar
    Dec 24 2007
    2019 Subaru Outback
    Austin, TX
    When you install new pads they push the calipers closer to the wheel spokes. And since you have et45 not 35, your spokes contour closer to the caliper than recommended. It's surprising you were even able to get the wheels bolted on. I recommend shaving down the face of the calipers in order for there to not be any rubbing, or shaving down the pads a little bit. The more mileage there is on the pads, the farther the calipers move from the spokes.
    DD: C5 RS6, Stock for now - Previous DD: B5 S4, K04 6speed, fastest color
    Aug 01 2008
    is really messy.
    you can shave the caliper? does that mess it up at all?
    Aug 01 2008
    is really messy.
    Oh and I lied I think the wheels are ET 35
    Oct 14 2009
    new jersey
    just put some spacers on.. if they dont rub much at all get 3mm to 5mm. if the wheel doesnt move at all if the car rolls forward. get 5mm to 8mm.. and be done with it. you will have a nicer stance.
    in my opinion, i wouldnt "shave" down anything... that sounds like a ghetto and stupid way to fix this.. you just purchased new pads. so ur goin to shave em down??? watttt the fuuuuu? and to me the brakes are 1 of the most important parts of a car.. y would u touch a caliper? just add some spacers. you might have to get longer lug bolts.
    my advice is find a friend who has 5x112 spacers. in the 1mm to Xmm sizes and ask to put them on ur car for a few minutes to see wat size you can get away with.
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    you can put 1mm thick washers on the lug bolts to measure what size spacer u are going to need.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Aug 01 2008
    is really messy.
    Drove to Achtuning today at lunch (from Seattle and back in under 60 min!) and picked up some 5mm spacers.
    Fingers crossed!.
    Established Member Two Rings buddysnack's Avatar
    Sep 29 2009
    2006 325 XIT, 2006 Cayman S sold
    I had the same issue, so I got my fenders rolled, and then ground a bit off my brakes. No spacers, no rubbing. Perhaps a bit ghetto. If I did not have stock brake calipers I might not have done so. Have not had a problem since.
    2001.5 B5 S4 Stage 3 - Frankenstyle.
    Nov 14 2006
    600hp glorified Beetle, Tacoma, motorcycles
    Renton, WA
    Shaving calipers isn't a big deal unless you go apeshit on them. I prefer spacers myself though because it also pushes the wheels out a bit, giving you a better stance.
    -Darrick
    No more Audis, but I can't seem to leave this place.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by KNaudi View Post
    nice trick
    Established Member Two Rings drhoadsveersixx's Avatar
    Feb 25 2010
    subaru impreza wagon
    reading pa
    i had to grind my brakes alot and i still had to use a 15 mm spacer dont be afraid to grind them just get grinder and keep grinding wheel flat i think its looks nicer also geting the nasty casting line out. make sure your use cover on your car the sparks will settle on the clear coat then rust.
    Xbox gamer tag drhoadsveersixx
    Feb 25 2010
    reading pa
    Dec 24 2007
    2019 Subaru Outback
    Austin, TX
    Quote Originally Posted by Silver Bullitt View Post
    Not at all. Just don't grind an assload off. Plus it gives you a reason to paint them too.
    Aug 01 2008
    is really messy.
    5mm spacers and a 2mm grind did it, Looks good. You can barely tell its ground. I just did the middle 3" of it where the spoke hit and it tapers to the original edge. Need to get some paint though. thinking black but may do a bright silver to match the car and contrast the black wheels.
    But first things first, I need to re bleed the system....still a bit mushy.
