So I have a couple of issues that started Saturday.
Started with the display for the transmission highlights each gear P N R D 4 3 2 when selected and shows 5 4 3 2 1 in TIP mode. Sporadically it would flash when D was selected, not allowing TIP mode to work. I VAG-COM’d it and it would not highlight D and would show gear selection of Z3 in VAG COM for Drive when this occurs. It does show that the up and down arrows for TIP shifting are working so I am sure it is not the magnets.
It appears to only occur when the engine/trans are nice and warm and all temperatures are up.
Today it went into limp mode highlighting all gears at all times and was stuck in 3rd gear.
I don’t have time to get under the car tonight or tomorrow, so when I do I would like a plan to see what the issue could be.
Might this be an issue with one of the electrical connectors? Simple electrical cleaner, dry and it could be gone? Anyone else have these same codes/display problems?
Thanks in Advance!
Codes:
VCDS Version: Release 10.6.1 Data version: 20100831 Monday,11,October,2010,16:49:25:37912
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 L
Component: 2.7l V6/5VT G 0001
Coding: 06751
Shop #: WSC 63251
VCID: 337BD1ED2B47
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 DL
Component: AG5 01V 2.7l5VT USA 1717
Coding: 00032
Shop #: WSC 63351
VCID: 7AE53CC94CAD
1 Fault Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 35-00 - -
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04397
Shop #: WSC 06342
VCID: 357FEFF52533
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
