Results 1 to 24 of 24
    Established Member Two Rings osiris07's Avatar
    Aug 23 2010
    Little Valley N.Y
    removing dp's to make Piggies for 6spd manual ???
    I got every thing i need to do so till i got to the heat shield above the front drive axles "3 allen bolts" well i got the two on the sides but HOW THE FUCK DO YOU GET THE TOP BOLT OUT ??????? please and thank you. . . patience and determination is key but there has to be more to it then that can some one give me there two penny's if they have done this and only if you have done this. . .
    Active Member Three Rings spinall4's Avatar
    Jan 10 2010
    Buffalo, NY
    oh boy gl shawn, did you get a new gasket set yet? if so what did that run you?
    Senior Member Three Rings jpm757's Avatar
    Nov 08 2008
    01.5 s4 avant, 86 325es
    CT/VT/ADKs
    cut the allen wrench and stick the end in the socket then use a bunch extensions
    I can make you custom die cut stickers
    check out PrimeCutsvinyl.com
    Mar 10 2009
    il
    these were a ***** when i first took them out. but yea you need to buy an allen head "socket" and get like a foot or so of extensions. then take off the wheel and it's super easy.
    Veteran Member Three Rings lbs4's Avatar
    Jun 14 2009
    01 S4.99 Grand Cherokee.89 240SX
    Vermont
    save the hassle and like they said, go buy a set of 3/8 drive socket allen and hex head sets. they will pay out in the end if you do a lot of your own work.
    Veteran Member Four Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    I have multiple extensions and flex bits specifically for sh*t like this
    Aug 23 2010
    Little Valley N.Y
    Thanks every one it all makes sence now when i get my car back in the shop on the lift i'll get'er done and let you know how i make out. Again thank's!!!
    Veteran Member Four Rings imola's Avatar
    May 23 2007
    It's a bitch to get it out so be sure to not put it back in next time
    sold :(
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Quote Originally Posted by imola View Post
    If you like cooked rubber. With the right tools it is VERY easy to R&R.
    Get allen head sockets, maybe even ball end allen sockets. Also wobble extensions. Napa sells decent tools at a reasonable price, if you don't use tools much Harbor freight sells them, also but are lower quality by far.
    Nov 08 2008
    CT/VT/ADKs
    put the heat shields back on, just leave the middle bolt out
    Aug 23 2010
    Little Valley N.Y
    i have all the tools needed just not the approach from said such Audizine member, Members!!!! again thank you I know this can be done
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    theres actually a cut out for these bolts and are easily accessable from the inner fender, and i would suggest reinstalling them. not too hard to do at all.
    RS6 hybrids and corn
    Aug 23 2010
    Little Valley N.Y
    and the gasket set shipped to the door is $26.50
    Veteran Member Three Rings joe dub's Avatar
    Sep 01 2008
    Illinois
    yah wheel off and a long extension its cake
    silver - RIP
    black - TAILS
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by joe dub View Post
    This, and a 2nd person. Working together and both of you having patience is crucial. Thankfully, my buddy has the patience of a saint, and I do not. It was balanced. But many extensions are key.
    One guy turns the bolt a little from the bottom, then another from the top of the car. Rinse, repeat. It's a major PITA, but a major sense of accomplishment and worth the reward afterward.
    Senior Member Two Rings jms-4's Avatar
    May 14 2009
    2000 Audi S4, 68 Mustang
    Renton, WA
    Quote Originally Posted by MikeyB3 View Post
    Same here, but we did it differently. One guy under the car holding the allen socket and the other on the outside of the car with all of the extensions turning the bolt.
    Patience is key. On this job, trying to go quickly is going to cost you somewhere.
    Jeff
    2000 S4
    Revo w/SPS3
    AMS TBB, Stern snub mount, Apikol Rear Diff Mount
    3" custom exhaust, Minor lemmi tweaks
    ST Coilovers
    710N, EBC Slotted + Dimpled
    Incognito Piggie Pipes, 034 Density Trans Mounts
    Voodoo MBC Ceramic in MBC only mode
    other stuff
    Established Member Two Rings WhssssS401's Avatar
    Oct 17 2010
    1990 300zx NA
    Sioux Falls, SD
    I did my piggies about 2 weeks ago and it went very smooth, With the axle shield I just took 2 long extensions and with my wheel still on just warped my arm around the suspension as I was laying under the car and got at the bolt in the middle from the top of the shield. I kinda found it worse to put it back in place, (take the wheel off, much easier anyway) The other bolt I found extremely difficult was the third dp bolt on the right on the drivers side dp, the axle is in the way for a normal wrench and just plain awkward. I ended up using a 6" extension then a 45 deg swivel and then another 6" extension. (buy a 17MM 90 deg swivel closed wrench) much much easier for the dp bolts. well anyway here are a few picks of the DP's and gutting them. I did the cut, gut and weld on the Downpipes.
    2001 Audi S4 Stage 2+
    APR Tuned Chip | Draintake Intake | 710n's | RS4 Clutch |
    ECS Light Flywheel | Piggie/Test Down Pipes |
    3" MagnaFlow Custom Exhaust | 18" HR8-MS Hartmann Wheels |
    225/40ZR/18 Continental Ext. | Vogtland GT2 coils | RS4 Bumper |
    Erik N.
    Aug 23 2010
    Little Valley N.Y
    Nice Thanks. . . you change your gaskets?
    Oct 17 2010
    1990 300zx NA
    Sioux Falls, SD
    I actually reused my gaskets. They looked to be in good shape but I plan on doing custom dp's later so I will be replacing the gasket then. It's not a bad idea to replace to old gasket though.
    Erik N.
    Aug 23 2010
    Little Valley N.Y
    plan on doing custom dp's later??? keep me updated!!
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by jpm757 View Post
    Dude, you know they sell allen head sockets, right? No need to hack up a perfectly good allen wrench
    Quote Originally Posted by WhssssS401 View Post
    Exactly, but you forgot one adjective: RATCHETING!
    OP, lots of extensions and THIS will save your life:
    http://www.northerntool.com/shop/too...9304_200319304
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Senior Member Two Rings Short4Law's Avatar
    May 25 2009
    Florida
    Forgive me in still learning the S4, but I though I read that you can get to the DP from the top of the motor.. ???
    May 02 2010
    Housotn, Texas
    Hated the dp on my s4 worst thing to do in my opinion but worth it when your finished
