Im assuming you are talking 300hp at the crank?
the k04-015 wont get there, the options are the gt2x, the new one uses water cooling now so its a prity good turbo, the frankenturbo f4h has just been dynoed on a b6 at 230awhp and 260ft/lbs on the uni stage 2+ tune and meth epic 45pg thread if you want a good read in the b6 forum, or the gtrs elim will easy get you there plus some.
if you meant 300awhp then its a another story, you are in the danger zone for rods, some get away with it some dont. a full frame gt2860r will do it, a gtrs might get there on a custom tune, a gt2871 or 2871 elim will get there on a tapp tune maybe on some of the uni ones. there are also 50trims etc that use journal bearings which are slightly kinder on the rods but spool a bit slower, or bullseye will build you prity much anything you want, a s256 will do it with some left over. the last option is the most expensive but really cool, forced performance will take a gt2860r or gt2871r and put a 68mm alloy compressor wheel on it along with some machine work and you get something that has gtrs spool with 2871 flow.
