Results 1 to 7 of 7
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    What does this thing do in my fender.
    I took my rear fender carpet out the other day for cleaning. This was behind it on the drivers side. What does it do?
    Veteran Member Four Rings vortexjunkie's Avatar
    Sep 12 2009
    Manteca/Lathrop
    im going to go with it has something to do with relieving pressure build up in the gas tank... just my guess
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Leak detection pump
    Veteran Member Four Rings AudiA4Turbo22's Avatar
    Dec 06 2007
    '03 Audi A4 1.8TQ Tip, '14 Mbz E63 S-AMG, '02 GMC Sierra Denali, '75 DJ5 Postal
    charcoal canister for fuel system.
    -Kirk
    AZ's First 2.0 Stroker 3076R Powered Tiptronic B6 Built by RavenMS. Powered by PSI Concepts & GIAC
    BetaAlphaTau Member #58
    Feb 22 2008
    ma/ct
    leak dection pump, it pressurizes the gas tank and evap system to test for leaks
    Aug 28 2007
    Thanks for the info. When should this filter be replaced. It looks in ok shape.
    Dec 06 2007
    i believe that is the filter that basically vents the air from the fuel tank to atmosphere after filtering the air. think hepa filter.
    -Kirk
