Results 1 to 9 of 9
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    DDM HID Fog lights install problem
    I am f'd! i got up this morning and took my front bumper off to install my new DDM HID kit for my fog lights. After a few minutes removing screws and installing the kit w/ error cancellers the system does not power on.
    I've been reading the forums for a while and thinking about doing this for a long time and i see that some of you have actually installed the slim ballast 35w w no problem.
    ok... so here i am, the bumper is still off the ground with the kit installed, when i turn the car on and the lights not even a flicker. I tried removing the error eliminator and still nothing. I see that the bulbs say 55w but i dont know if that matters since i have the slim ballast 35w, i should be getting something. Do i need to do some vag?
    Please help me!
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Veteran Member Three Rings CystmX's Avatar
    Feb 04 2010
    Andrews AFB, MD
    I installed mine a few weeks ago with no problems. Are you sure you have the ground going to ground and power going to power? Did you actually start your car and then try to turn them on?
    Established Member Two Rings Paradigm's Avatar
    Feb 03 2010
    Syracuse, NY
    dude. you have a 55w bulb, it will not fire up with a 35w ballast. they need to match.
    Senior Member Three Rings Boxmods360's Avatar
    Jan 14 2010
    refrigerator, tools, Audi
    Florida
    did you buy from DDM tuning?
    2008 A4 2.0T Quartz Grey - Vag-com - TSW Croft 19" 8.5F 9.5B - 10" Alpine Type R sub w/ PDX-M6 amp in a custom made fiberglass box - AUX mod - smoked reflectors - Plasti dip grill & window trim- 5000K Fogs - Red LED interior - Homemade Carbon Fiber trim - 640 mod - REVO ST1 - APR carbonio - OEM Xenon headlights w/ Phil's LED w/ 6000k Headlights
    My CF trim <-click-
    Established Member Two Rings king505's Avatar
    Jan 13 2009
    2005.5 B7 A4 2.0T Q TIP
    Veteran Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    B7 RS4
    Québec
    I know it's off topic a bit, but really you have to take off the whole bumper?
    I read if you got small hands you can do it all from the front by taking out the grills...
    Senior Member Three Rings theklug's Avatar
    Jul 01 2009
    '08 B7/'89 e30 5speed/'81 380sl
    Philadelphia
    ^^Check your connections again
    Brown = -
    White = +
    I'm pretty sure you have too, its tricky enough getting the ballast and all the other stuff a nice spot to install too. I used some strong double sided tape and could have never done it without removing the bumper.
    08 B7 2.0T Brilliant Red|APR Stage II|Stasis SS|VMR 18'' v710|FLY's Bixenons|HID Fogs|VMR TP|RS4 Sway|VMR Vent Boost Gauge|20% tint|RS4 Grille|Debadged|LED Things|VAG Goodies ............and it's still slow
    Oct 01 2010
    b7 a4 2.0T 6MT
    Quote Originally Posted by Paradigm View Post
    this!
    Mar 27 2008
    Allen, TX
    Yes i bougth them from DDM Tuning directly with the error decoder, i tested the power and it was ok. so after checking the polarity of the cables i saw that the stupid connectors are reversed (thanks theklug), i fixed and they turned on nicely.
    Yes, i know it sucks but you have to remove the bumper because if you try to reach it from underneath the car the because of the intercooler ducts block the access. It only takes couple of extra minutes to remove the bumper.
    thank you for your support.
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    If you have an S-Line bumper you really don't have to remove the bumper...just pull out the housings around your fogs. But if your non S-Line then I've heard you have to remove the bumper.
    @martino_motorsport
