Results 1 to 33 of 33
    Dec 05 2006
    So. Cal.
    Woke up this morning to a package from PURE MOTORSPORTS!
    Yes, I said Pure Motorsports. As some of you know, I have not seen eye to eye with Mike for one past issue. Well, he called me and went above and beyond what any Merchant would have even done, to win me over, and did he ever.
    All I can say is that I will be heading to Pure Motorsports as my first go to shop for all my needs for both my Audi and my VW. Thanks Mike, you ROCK!
    That being said, on to what arrived, which by the way, arrived way before I though it would.
    I will be installing them this week and if needed I can do a DIY if anyone is interested. I hear that the front shock needs to be removed to get these in, but I am hoping that this isn't the case as I'm running Motorsports.
    Without pulling the wheel off, it looks like the front uppers can be removed without taking off the shock. I'm probably missing something that I will realize when I get in there.
    Below is a pic of the stock suspension system. See how the spring is in the way. It's not like that with the Motorsports. However, I think my other issue is going to be how the bolt slides out of the UCA. I think that the underside of the shock tower is going to stop the UCA bolt from coming completely out. Maybe I can just loosen the shock tower bolts without removing the shock.
    If anyone has any insight (Koolade), chime in!
    Once Again, Thanks Mike, I am grateful to you. Ok, off to.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    good to see you are back in the game
    Dec 05 2006
    So. Cal.
    Drew baby, I was never out, just layin' low. When are we going to see you again?
    Veteran Member Four Rings witwer4444's Avatar
    Dec 13 2008
    Palm Beach FL
    Sunday Morning Delivery? Thats awesome
    Current:
    2005 Black W211 E55 AMG
    Sold:
    2002 Stering Grey E39 M5
    2001 Nogaro Blue S4
    Dec 05 2006
    So. Cal.
    Today is Sunday? Oh, it must have arrived yesterday while I was at work. Saturday delivery is still Awesome!
    Jul 27 2004
    Orange County
    right on. hopefully i'll make it out one of these days to say hi...
    Dec 13 2008
    Palm Beach FL
    Wordddddd
    Current:
    Sold:
    2001 Nogaro Blue S4
    Senior Member Three Rings alwaysaudi's Avatar
    Mar 11 2008
    2008 RS4, 2011 A3 2.0T Quattro, 73 MG Miget, 87 325is Chumpcar, 2000 323i SCCA racecar
    VIR
    Mine have been on for about 4 wks. I removed the whole setup, but understand your situation. I would say if you have the right tools it is possible. I agree that with lessening the 3 shock tower bolts the UCA bolts should have room to slide out. Good luck. I case you didn't know stern ships the control arms at stock length so if your alignment is good you have time to re align without fear severe tire wear. I did mine about 2 wks after install and my numbers were almost dead on from previously...I just had them dial in 0 toe and 1.3 degree camber.
    2008 Ibis RS4 Titanium package - Milltek CB - Stasis MS - H-sways F&R - EBwerk droplinks - JHM R3 clutch + LWFW - JHM LW Crank pulley - JHM IM spacers - Roti SNAs with 275 Supersports
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    I recall you installed the MS kit yourself, with your exp you should be able to install the arms without removing the struts. I have the same setup as you and did not have to remove them. YOu will want to lower them a tad though,
    Veteran Member Three Rings euroazfck's Avatar
    Jul 18 2010
    98 audi a4_ 88 civc hatch "jdm"
    colorado
    Nice
    Oct 26 2009
    Beaver Creek, CO
    I'm going to get myself a set of adjustable control arms at some stage. For now, I will just envy you, sir.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    I have seen that coilover setup on another RS4 that came into the shop and couldn't find it any where when I searched. The H&R, Vogtland, and Stasis coilovers kits come up when I look on sites but not anything that looks like that. Please where did you get that Motorsports coilover setup?
    Also nice phone, I have the same thing.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by ngng View Post
    You're right, I did install the MS kit myself. If loosening the 3 strut tower bolts to lower the top plate is all that is needed, I'll be in heaven.
    Quote Originally Posted by JimmyBones View Post
    I purchased my Stasis Motorsports from Brian before he started Rotiform.
    What do the Motorsports that you are familiar with look like. Blue springs (Hyperco)? Other than spring color, they should look identical.
    Apr 03 2010
    Northern Virginia
    You can probably take the three top strut bolts out and slide the top over a little bit to get the front upper control arm bolt out.
    The Motorsports I remember were just like yours with the red inverted springs. I will do some more searching for Stasis parts and see if I can find anything.
    Dec 05 2006
    So. Cal.
    The picture of the Motorsport setup on the Stasis site are not for the B7 body. I don't know what car they are from. It's just a reference picture.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    ooooh...upper control arms?
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Oct 14 2007
    Mammoth Lakes, Ca
    damn...adjustable, camber and caster...very nice!
    Dec 05 2006
    So. Cal.
    Very nice indeed. Had to sell off a few exhaust systems in my backyard to get them, but hey, you gotta do what you gotta do. What's up with your car? BTW, Miss you guys... Lets get together and have a drink or five.
    Oct 14 2007
    Mammoth Lakes, Ca
    hahahaha!!! Yup, you gotta do what you gotta do sometimes! Car is great, she's got 49K on the clock. Wondering if I should CPO or extend warranty. Don't really have the cash for either. The water pump in the Q5 broke last week. Apparently there's a recall, of course my mail still goes to LA, so I didn't get it. The people at Allison Audi in Reno are really good, they fixed the car in one day and gave us a 2011 Q5 as a loner. SWEET!
    Also have to get winter wheels/tires for the Q5...looking at these Wheels and some Blizzaks for deep snow traction!
    We are planning to be in LA this weekend with a Uhaul to get the big stuff from Culver City up to Mammoth. I really need to rent out the condo, so everything has to be moved out of there this weekend. Maybe we can shoot for a drink or two, I'll talk it over with the boss.
    Dec 05 2006
    So. Cal.
    Cool! I am off Saturday and will be at the house detailing a few cars. Picked up a Flex 3401 and the complete line of Menzerna detailing products.
    Established Member Two Rings jpo's Avatar
    Jun 22 2008
    Calgary
    You have the cleanest car underside ever.
    Established Member Two Rings nfs1000f's Avatar
    Sep 22 2010
    1987 Honda Hurricane 1000. Gone: 1986 4000, 2001 A6, 2005 B7 S4
    VESTAL, NY
    Quote Originally Posted by jpo View Post
    I was thinking the same thing too. Looks like it just rolled of the factory line. This car looks like it has never seen a wet road.
    Oct 14 2007
    Mammoth Lakes, Ca
    ^^^^ That's because Ed doesn't drive the car!!!
    Dec 05 2006
    So. Cal.
    I actually took it out the other day and it ended up raining. Had to wait it out under a freeway underpass for a hour.
    Sep 22 2010
    VESTAL, NY
    You're kidding, right?
    Dec 05 2006
    So. Cal.
    Yes, I'm kidding. It was a light sprinkle so I continued driving.
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Detailing now Ed?
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Dec 05 2006
    So. Cal.
    Just hooking up a few co-workers. They want to pay but I'm not charging. Dropped $700 at Detailers Domain, so I'm pretty dialed in. The cars are gonna look like glass.
    Oct 14 2007
    Mammoth Lakes, Ca
    Damn man! Looks like I don't have enough dough to make it down to LA this weekend...I really wish I could get the S4 into your capable hands Ed. Oh well, maybe next weekend.
    Feb 01 2007
    Quote Originally Posted by channad View Post
    I'd be willing to sub my car for channa's
    Senior Member Two Rings CKS's Avatar
    Sep 28 2009
    Truckee, CA
    Also have to get winter wheels/tires for the Q5...looking at these Wheels and some Blizzaks for deep snow traction!.
    That's interesting. I had a bad experience with Allison on a few fronts:
    1. They did an oil change and said they didn't have loaners. What determines whether you get a loaner or not?
    2. They dented and chipped the paint on my car and claimed it wasn't their fault. They eventually relented and repainted the bumper, twice since they screwed it up the first time
    3. They didn't know how to initiate an oil consumption test after I was very clear that I wanted one (it could be b/c they don't think I really need one)
    Dec 05 2006
    So. Cal.
    ^^ You just polluted my thread. OT
    Sep 28 2009
    Truckee, CA
    You're right, sorry about that!
