Results 1 to 13 of 13
Thread: Been a While!
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    Been a While!
    I have had a project in the works for quite some time now and the final result is just about finished now...
    the changes...
    -ER comp intercooler with custom piping for AEB head, full race manifold and Bullseye power s256/.7 AR turbo
    -New exhaust cam (intake was already done, old exhaust cam was a bit too aggressive)
    -HKS SQV 3 BOV (for now, might end up going to tial)
    -Eurodyne Maestro Software (being tuned for E85 ethanol)
    -Cam advance delete (AEB), for reliability
    this is all in addition to what was already done, which is quite extensive (several of you know about the original build)..but to sum it up
    -built motor..rods, pistons, etc
    -AEB head, ported and polished, oversized valves all around, built head, cams, etc
    -Bullseye Power S256 turbo, .70 AR, Tial 44mm external WG
    -Full Race exhaust manifold, AEB intake manifold
    -1050cc injectors, impedance converted
    -South Bend clutch and Dxd Pressure plate, light weight single mass steel flywheel
    -B5 retro fuel system with adjustable FPR and fuel return line, upgraded pump.
    etc etc etc
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Jun 08 2008
    Calgary AB Canada
    Pics!
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    will do when its finished...still some buttoning up left to do.
    USP CLUB MEMBER #26
    Mar 27 2005
    The Cold North
    good to see this is all coming along ted. Seems like we have all moved forward to build motors and larger turbo's since the old K04 days.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Sounds strong.
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    it certainly should be. I guess we will see in the next week or two if it was all a success!
    USP CLUB MEMBER #26
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Nice work, Ted. I look forward to seeing the car again soon.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Are u still on the stock bore and stroke (der tru 1.8... actually 1786cc)? Any plans to hit the dyno?
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    1803 cc which is a slight bore, no stroke...so a true 1.8. Dyno will definitely hit in the near future...once I get the base file tweaked a bit and get her dialed in!
    USP CLUB MEMBER #26
    Jun 22 2009
    Dundalk, MD
    Hey old timer! Haha jk good to hear from you. Does the car feel quicker with the AEB?
    Veteran Member Three Rings Euro's Avatar
    Sep 18 2006
    Bimmers
    Portland
    Dude! No pics!?
    Com'on.
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    Quote Originally Posted by [email protected]. View Post
    Its been AEB since the first rebuild, and that was coming from a k04 powered car. The head is nice though with the big port advantages which were further advanced via the work we did on it. I still have a little of work left to do until it is running again, but probably just a day or so away until it fires for the first time in this configuration. Other enhancements obviously due to the new interccooler (LONG overdue) will be totally reworked intake piping for a true cold air setup via the bumper grille, MAF delete with the new software, and obviously FULL tunability and control via Maestro 7...which is really great! I can now have basically 2 setups..one for ethanol and one for 91 oct that can all be tweaked as needed as much as needed! I will be doing the initial setup on e85 since its actually quite a bit easier to tune for and a bit more forgiving and it will develop from there!
    USP CLUB MEMBER #26
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    Quote Originally Posted by Euro View Post
    Dude! No pics!?
    Com'on.
    The car is in quite a few pieces at the moment...when it is all together I will bust out the DSLR and get some awesome shots. You can see about 90% of what it is today in my gallery here. I also have some shots in there of the head work and other stuff that was completed when the rebuild of the block/head first happened!
    USP CLUB MEMBER #26
