Results 1 to 17 of 17
    Established Member Two Rings lil98civi's Avatar
    Oct 26 2009
    Illinois
    Chipped b5 s4 hesitating and studdering help!!!!
    Ok so 2 days ago i got my revo tuned ecu put it in and went for a test drive. Everything was fine boosted to 16 psi and held fine. It was fine for a couple pulls, then the next day as soon as i went above any boost (0-16) it would studder and hesitate but would make full boost which was very wierd. I saw that one of the vacuum lines from my diverter valve was very brittle so i thought it could be that and changed it, sames thing didnt fix anything. Im still running the stock diverter valves and its throwing no codes. Has anyone had a problem like this or heard of one what should i start with? I havent changed the fuel filter in a very long time so could that possibly help? It feels like its a misfire but no codes at all very wierd.
    Established Member Two Rings drhoadsveersixx's Avatar
    Feb 25 2010
    subaru impreza wagon
    reading pa
    i had the same problem and so i just bought a new fuel fliter and got brk7es plugs and gapped them to 0.28 and did the fuel fliter and havnt had the problem. mine i used to be full boost and it would just fall on its face and the also would boost oddly
    Xbox gamer tag drhoadsveersixx
    Oct 26 2009
    Illinois
    im going to do the fuel filter anyways just cause it should be done and i did do plugs about 4 months ago so they should be fine its just wierd that im actually making boost. It gets worse and worse everytime i hit it.
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    you should also upgrade your DVs if you are chipped..
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Oct 26 2009
    Illinois
    Yes i have 710n i have at my work i have to put in just have been too lazy until this happened haha. Would a diverter valve cause a problem like this and still make boost and no CEL?
    Established Member Two Rings wunderman4's Avatar
    Aug 10 2008
    2015 VW Passat 1.8T
    Phoenix, Arizona
    I had a problem where the my car would stutter out around 4k rpms so I replaced the Dvs (034 Billet) the coil packs and plugs, and the N75 valve. They all helped a little but the N75 did the trick and fixed it completly so I'd recommend getting the N75, then Dv's, and if you start throwing codes for it the coil packs.
    Hope that helps
    Veteran Member Three Rings Dubluv11's Avatar
    Jan 08 2010
    00 S4
    Quote Originally Posted by lil98civi View Post
    you may have a fault code but no cel... but yes a bunged up diverter valve could cause this... install the 710n's and report back..
    Jan 08 2010
    00 S4
    Quote Originally Posted by wunderman4 View Post
    Hope that helps
    thats the expensive way of diagnosing a problem..
    Feb 25 2010
    reading pa
    i forgot thats were i started 034 dv's
    Veteran Member Four Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    Long Island NY & Kent OH
    When this happened to me it was the spark plugs. I replaced all and the studdering and hesitation went away.
    Garage: b5 s4 silver stg3 f21s
    RIP Daz 4/14/16. Legend.
    Active Member Two Rings audimatt777's Avatar
    May 04 2010
    2001 Audi S4, 1964 impala
    Washington State
    I would have to agree with above.. I fought with misfire/hesitation problems for a long time. Finally switched my newly replaced plugs with Bosch F5DPOR (sidefires) and haven't had a problem since! my car is running 24 lbs of boost w/ meth
    Matt Litteral
    2001 S4 Stg. 3+
    Veteran Member Three Rings JWatson's Avatar
    Dec 14 2009
    2001.5 S4 ,1947 Mercury Coupe
    Rapid City
    Should pressure test too, just to be sure.
    01.5 S4 (on meth)
    Sep 16 2005
    Asheville, NC
    You should read the diagnosing misfires thread and go from there. This car is way too expensive to throw parts at.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Veteran Member Three Rings lbs4's Avatar
    Jun 14 2009
    01 S4.99 Grand Cherokee.89 240SX
    Vermont
    it sounds like your car was stock. you liked the boost did a few pulls and ripped your throttle body boot! stock TBB's dont like all the extra boost from chips. so pull the clamp off and it probably ripped right along the edge of the boot.
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    Ok I need to correct some people here.. OEM recommend spark plug gap is .016 - .024 inches... I don't understand why people keep posting the .028 or .28 as that is not correct. Check with any Audi tech if you don't believe me. Also never believe a pre-gaped spark plug is correct. First check them before you install them. What I would recommend is first check and see if you have any codes. Likely you will have a random misfire. In that case take all of your spark plugs out and make sure they are gaped between .016 - .024 inches. If you do that and still have a problem you may have a bad ICM or coilpack depending on with cylinders are misfiring.
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    OP, that's rookie! Get those DVs in there, replace your TBB and DONT take the 1st showcase on the Price Is Right!
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by mys4.org View Post
    I think that's because the factory manual does indeed call for this(it may be even smaller at .014) on the 2.7t, but I think this is an error on the manual's part. Most people, myself included set the gap @.028 for a chipped, K03 car and this is where OE suppliers set the gap(.032 most likely).
    .28 is definitely not right
    08 S4- Stock SOLD
