Results 1 to 6 of 6
    Oct 09 2010
    fort myers fl
    Gas overflow problem...please helppp!
    When i go to put gas in my 2000 audi a4 the pump always stops and over flows when its even on empty. whyyy? its like theres no breather hole or its maybe clogged?
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    The gas tank breather/vent may be clogged, mine was replaced under warranty a long while back. The breather/vent got damaged somehow and it would only let me put in a few tenths of a gallon at a time. Not sure how you would test this or unclog it without doing more damage.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Oct 09 2010
    fort myers fl
    Okay i understand, thanks.
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    Back the nozel out more, need air to flow as well.
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Jun 30 2008
    Erie, Pennsylvania
    You shouldn't need to back the nozzle out, there is a tank vent system for this. It obviously isn't working though. You should be able to disconnect the tank vent hose from the charcoal canister (make it vent directly to atmosphere) to fix this temporarily. Most likely the charcoal canister is clogged. I think you can disconnect that line in the one of the rear wheel wells, but I can't say for sure. I've never had to do it...yet.
    Jun 06 2008
    Port Moody, Canada
    yeah but if you dont where are those vapors gonna go that set the sniffer off?
