Originally Posted by
redneck truck
U2redeye - you just finished with a set of the sumitomos I bought? That's comforting - maybe this will be a good buy after all. Any specific commentary with regard to their handling characteristics in specific situations?
they are some of the best tires i've purchased EVER without spending $300+ per tire. they arent noisy on the road until just before you have to get rid of them, not unlike most tires. to keep from going too in depth, wet traction is superb and dry traction is excellent. several trips to GA and SC from NY thru rain, 90+degree summers in GA, and a bit of snow during a last minute trip to NY...no autocross, but quite a few spirited runs around town...these tires held up to anything i threw at them.
the only "Buyer: Beware" tip i have is simply this....make sure you rotate them often. they wear a bit faster than most and like i stated before, i literally tore up those tires. they have an almost seamless tread on the inside of the tire specifically to reduce the noise created from uneven wear from the rear camber. i pushed the tires to the limit of their wear on the way to SC from NY. i was hoping to change them after my trip, but that very same seamless inner tread shredded under load. no blow-out (thank god) but i had to immediately get a set in Boondocks, Virginia. with that said, maintain frequent rotation and be weary of the treadwear. dont push the life of the tire and you will be very happy!
i hope that helped...anything else you need to know?
