Results 1 to 18 of 18
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Crappy ass plastic
    For the past few days I've noticed that I lost ~ 2 in Hg of vacuum when at idle. It was a nice day today so I decided to poke around under the hood and see if I could find the culprit. It didn't take long. The piece of crap plastic dip stick tube was broken into two sections about half way down. I fixed it for now with good 'ol duct tape. Guess I'll be picking up a new one on Monday. So many of these have been reported broken that it's probably a good idea to go ahead and replace yours before it splits. Cheap enough insurance.
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    i made this today and found lots of little leaks! as of tonight i spike at 11 again! im so happy!
    Dec 28 2006
    Western Maryland
    Very innovative
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by heywier427 View Post
    Stock tuning?
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    How much did this badboy cost to make?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Exanimas View Post
    Stock tuning?
    I certainly hope so @11 psi!
    Active Member Three Rings BAB1990's Avatar
    Jun 26 2010
    Old Guy, would the oil cooler hose if it was leaking or not sealed properly would that cause a vacuum leak? The one from the crankcase into the oil cooler.
    Mods:
    Full-Race -|- Tial 44mm Wastegate -|- 5557E BB PTE -|- Custom Downpipe -|- 630 Injectors -|- Maestro Tuned -|-Open Dump -|- Custom Intercooler piping -|- Built Bottom End -|- AMB top (Soon to be AEB) -|- 355 BBK 4 Pot BBK -|- KW V1 -|- 19"V710's 9.5 Rear Matte Black -|- Authentic Otty Front -|- Authentic ABT Sides -|- Black Vinyl Roof -|- Too many to list
    Jan 08 2010
    CT Shoreline
    yes stock tuning...im so torn between putting money into this car or my house! id really like 30lbs!!! but for now i spike at 11 hold ten for a sec, then drop to 7-8 or so. id really like 30lbs!!!
    it cost about 20 bucks to make.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by BAB1990 View Post
    I assume you are referring to the block vent host that plugs in above the oil cooler. If it isn't sealed properly it can let in excess air through the crankcase breather valve and act like a vacuum leak. Normally at idle the air is metered into the block via the PRV (pressure regulating valve) on the back of the valve cover (or the TIP on an '02). The excess air will cause a slight drop in vacuum at idle. Pretty much the same thing that occurred with my broken dip stick tube.
    Jun 26 2010
    Yes that hose.
    Than that must be a part of my vac leak. Under positive pressure (boost) would that act like a leak too? Currently it is just rigged up with heater hose into the block vent host and ever since than, boost seems to be much slower.
    Mods:
    Mar 09 2008
    is full of crap.
    Boston, MA
    Haha, I was alluding to the fact that he should get some sort of a tune ASAP and start really enjoying his car
    -Nick
    Jan 08 2010
    CT Shoreline
    no tempting me!!!
    all i need is injectors and a front mount. i have dv, tp, dp, and exhuast. oh yeah, and the tune...but i came from a 40 hp 1.6 n/a diesel. this thing is a freaking rocket ship to me right now!
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    I tend to break them every time when doing an alternator on a TT or a coolant block plug on an A4. If you notice the new dipstick tube is an orange color and when that orange turns to yellow the tube will break with almost any movement.
    I also tend to break the plastic crankcase breather line on the bottom of the Y tube at the back of the valve cover a lot.
    Audi's cheap plastics suck for these engines.
    Mar 09 2008
    is full of crap.
    Boston, MA
    no tempting me!!!
    Hahaha! You drove a lawn mower before?
    Honestly, if my next car has a turbo, I'm chipping/tuning it within 24 hours of purchasing it. It's such a huge difference. Me and another member were testing out his car after a coilpack replacement and I told him floor it. 10 seconds later I was like, "... I said floor it", he's like "I am!". Turns out he was on stock tuning. I felt bad for him after that. The end.
    -Nick
    Dec 28 2006
    Western Maryland
    As long as your check valves and block breathers are functioning properly this should not exhibit as a boost leak. Those valves will prevent a boost signal from reaching the block. it will only mimic a vacuum leak.
    Jun 26 2010
    I don't have my check valves =(
    Mods:
    Dec 28 2006
    Western Maryland
    So am I correct in assuming you have deleted everything except the lower block breather tube and you have that connected to the upper breather tube and dumping from there? If this is the case then it should not cause a boost leak or a vacuum leak.
    Jun 26 2010
    Correct!
    Thank you for your wise wisdom :)
    Mods:
