Results 1 to 7 of 7
Thread: An opinion!
    Senior Member Three Rings a3s-line's Avatar
    Nov 25 2008
    A4 B7 1.8T FWD
    Athens,Greece
    An opinion!
    Hello dear Audiziners!
    I have a serious question : I have a A4 B7 1,8T fwd (I live in Greece that's why),with stage one custom flash, Forge 005, free flow panel air filter, Bosch sparks (one setting colder) and Hitachi coils.The exhaust is OEM and I am thinking of replacing the two back boxes (right and left) with something less restrictive (custom built).Is this possible without changing something on the program? I know that the gains will be little but I like to do that. Thanks!
    A4 B7 1.8T FWD, OEM Black out grill conversion,, red calipers, s-line springs, slottted and cross drilled front rotors (galfer), tuning brake pads (galfer), stainless steel brake lines, RS4 pedals and footrest,OEM TT MKII 8,5X17 wheels,235/45/17 tyres, VW touareg flashlight instead of lighter, cupra R lip, black mirror covers, ECU Flash custom stage 1+, TT/S3 injectors, Boost Brothers FMIC,turbo back exhaust,200 cpsi magnaflow HFC,Forge 006, HID 6000K & fogs 6000K
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by a3s-line View Post
    You won't have to change anything on the program, since like you said there will be little to no gains. Even if you got a full exhaust, your program would be fine.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Nov 25 2008
    A4 B7 1.8T FWD
    Athens,Greece
    thanks for the answer mate.Some people here in Greece say that if I change big things in the exhaust I will need some TT/S3 injectors because the turbo will spool faster and gain more overboost. This will cause shortage of gasoline in the peak and will cause the engine to run a lean mixture. The programmer said that no matter I change the exhaust nothing have to be changed in the program because it is running on 14,7:1. A friend of mine gave me a new N75 valve from TT225.Is it wise to install it also? The car runs 0,9 Ct and 1,2 overboost. By the way what is the capacity of the OEM A4 1,8T BFB injectors and the difference of the TT225 or S3? thanks again!
    Senior Member Three Rings Outerfroggy1's Avatar
    Nov 18 2009
    Newfoundland, Canada
    you could run an open dump 12 inches off the turbo and you would be fine. loud... but fine haha
    Dec 06 2007
    Quote Originally Posted by Outerfroggy1 View Post
    uhm, not quite. If you drive with basically an open ended testpipe you literally will be shooting flames all the time and it's actually not healthy for your car since all the heat coming off the turbo that is made to be routed through the exhaust to cool down will just be coming out the top. The engine bay will be running much much hotter as all that hot air will remain within the engine bay.
    -Kirk
    BetaAlphaTau Member #58
    Nov 25 2008
    A4 B7 1.8T FWD
    Athens,Greece
    No,no guys.I don't like the noise since I travel a lot in the highway. I prefer a bit bass sound, so I don't like to ''open up'' the exhaust.Which is the preferable diameter according my setup?Any ideas about the injectors that I previously asked?
    Nov 18 2009
    Quote Originally Posted by AudiA4Turbo22 View Post
    LOL well yes i was exaggerating a little, but a given exhaust is not going to mess with your tune
