Results 1 to 9 of 9
    Sep 29 2009
    Cary, NC
    Ac Problem Please help!!!!!!!!!!
    Yesterday I replaced two window regulators, that went okay but in the process of reconnecting everything the car was turned on doors were open and the battery died. got a jump and everything was working or so i thought, today after washing the car since it had been sitting in my garage for a week (poor thing) I go to drive windows work radio works (ac doesn't, the off light is lit along with the rear defrost, but it will not come on not temperature nothing,when i start the car it sounds like the compressor might start but it doesn't. I pulled the blower fuse next to the steering wheel and that was fine. Any ideas? please help.......... no ac no heat is crazy.
    Senior Member Three Rings ADNpro's Avatar
    Sep 11 2009
    2013 WRX Hatch | 2010 Mazda 3
    Westfield, NY
    Could be a short somewhere perhaps?
    That's all I can think of, but I don't know much at all about electrical systems and what not.
    Sep 29 2009
    Cary, NC
    What could i have shorted with door wiring? is there something in the doors that could affect that?
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    how long has i been since you used it last? chances are that its not connected to when you did the regualators
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Sep 29 2009
    Cary, NC
    One week exactly.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    there is a possibility that the system was right on the verge of being to low and that time was just enough, the a/c comp wont kick on unless there is a certain amount of pressure in the system, and you said you have no heat either? if thats the case then there has to be something wrong with the climate control
    99 A4 1.8TQM:
    00 B5 S4
    Sep 29 2009
    Cary, NC
    Meaning what exactly? how would i check the heat if no temperature will pop on the screen the only other thing I didn't mention was my ac over the summer was not as cold as it use to be, I was thinking of getting it charged but never did.
    Sep 29 2009
    Cary, NC
    is there stuff I should check, to sort of narrow down the problem?
    Sep 29 2009
    Cary, NC
    The rear defrost button was stuck, thank you anyway... I was about to sh$%t as I just save 700 doing the window regulators my self they only cost 65 each side new on ebay and the dealer wanted to charge 400 per side installed, I thought this was going to be a expensive fix........ thank god.
