Results 1 to 10 of 10
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    Yet another ET question, but an easy one i think..
    So I've tried understanding the wheel width calculators floating around here but my head goes all fuzzy when I try to figure this stuff out...basically all I want to know is if a 9.0'' wide 18'' wheel with an offset of 48 will fit in the back on our cars. Or will I need spacers, wheel bolts, fender rollage, etc...I currently have OEM sport suspension, and will probably be running coilovers come spring, but no major slammage in mind though, just a tad lower than stock sport.
    wheels in question: the fronts should fit fine right ? ( 18x8 et45)
    http://www.raderwerks.com/product/ag-310-gm
    I'm just here for the free coffee
    Jun 08 2008
    Calgary AB Canada
    Ive test fitted some 18x9 ET35's and theyre flush with my rear fenders, an ET45 will be tucking slightly, so youll be fine
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    yea they are actually et48, not 45, should still clear? And if they tuck i can just run a small spacer and be in the clear right?
    Jun 08 2008
    Calgary AB Canada
    http://www.1010tires.com/WheelOffsetCalculator.asp
    An ET48 will tuck even more than a 45. Best way to go about buying spacers is mounting the wheels and measuring how much further out you want the wheel to stick out
    Stock. For now...
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    yea i was using that calculator but I just came across the actual definition of what and how an ET works here:
    http://en.wikipedia.org/wiki/Offset_(wheel)
    And it really helped clear things out. From what i can tell an et48 wheel in a 9'' will need something around 10mm's to be flush to the fender. I want it flush, no poke or tuck so I think thats what i will be going with. And I've always wondered what ''ET'' meant, it actually means Einpresstiefe (In german) or ''insertion depth'' in english. fun fact to know!
    Senior Member Two Rings alpinevr's Avatar
    Feb 28 2009
    Spokane, wa
    I would go with a 15mm spacer in the rear and a 10mm in the front. I'm running 19x9 et29 and sit pretty flush with my fenders
    Feb 28 2009
    Spokane, wa
    And it also depends on what size tire you want to run to decide on the size of spacers you should use
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    Quote Originally Posted by alpinevr View Post
    I dont want to run any wider than stock width so 235-18. I imagine I'll be getting just a tad of stretch on a 9inch wheel, and not really any on the front 8''.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Definitely get spacers. ET48 is too far in. The USP 18x8 wheels have an offset of ET43. 10mm spacers up front and 15mm spacers for the rear should work.
    USP CLUB MEMBER #34
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    18x9's et30 would be perfect
